Idiot Alert!
Sulli79 Oct 29, 2013
  1. Sulli79
    Sulli79 Active Member
    541
    37
    Help required!
    What is the best way to remove the 2 torx bolts that hold the wing on, the ones that face away from you mid way between the front door hinges?
  2. Bradderz_1988
    3,958
    238
    Torx bit and 7mm ratchet spanner maybe ??
  3. aragorn
    18,444
    848
    remove the arch liner, then remove the little plastic insert that fills the gap between wing and shell, and they just unscrew...
  4. Sulli79
    541
    37
    its the drivers one thats giving me grief, broken my torx bits trying, and i'm doing lefty loosey lol!
  5. aragorn
    18,444
    848
    are you doing it from the arch side?
  6. Sulli79
    541
    37
    Yeah it was from the arch side. Off now one came out ok in the end, the other claimed 1 torx key, 2 torx bits and a torx socket, all decent brands. A chocolate brand bit in an impact driver ended it reign of frustration!
    no idea what was going on there, somebody with hammer hands did that one up.
  7. Oranoco
    Oranoco Well-Known Member
    3,957
    404
    Annoying when people just swing on bolts, there are torque settings for a reason. FT is not a torque setting when I last checked.
    AR-rkon likes this.
