Idea's on this code? is it a common one?
Andrew@A.L.D Nov 14, 2010
  1. Andrew@A.L.D
    3,879
    617
    17834/P1426/005158 - EVAP Purge Valve (N80): Open Circuit
    Possible Symptoms
    Malfunction Indicator Ligh (MIL) active
    Possible Causes
    EVAP Purge Valve (N80) faulty
    Wiring/Connectors from/to EVAP Purge Valve (N80) faulty
    Fuel Pump Relay (J17) faulty
    Possible Solutions
    Check EVAP Purge Valve (N80)
    Check Wiring/Connectors from/to EVAP Purge Valve (N80)
    Check Fuel Pump Relay (J17)
  2. <tuffty/>
    21,572
    4,047
    Thats the valve at the top of the charcoal canister... is it unplugged?
  3. Andrew@A.L.D
    3,879
    617
    Arr thats ok then, i think the wire to it is a bit naff last time i looked.
    nothing bad then
