Idea on codes
rodenal Dec 7, 2006
  1. rodenal
    rodenal Active Member
    1,992
    Im relatively new to vag com and have been running a few checks on my car, can anyone give me a bit more information on what the following codes mean(if im being an idiot please feel free to tell me also lol)
    Chassis Type: 8L - Audi A3/S3
    Scan: 01,02,03,08,15,17,22,35,37,45,54,55,56
    Address 17 -------------------------------------------------------
    Controller: 8L0 919 910 A
    Component: AB-KOMBIINSTR. VDO D07
    Coding: 08442
    Shop #: WSC 00000
    IMMO-IDENTNR: AUZ7Z0T0031761
    1 Fault Found:
    01176 - Key
    07-00 - Signal to Low
    Address 35 -------------------------------------------------------
    Controller: 8LO 862 257 A
    Component: ZV-Pumpe, DWA
    Coding: 01288
    Shop #: WSC 06313
    1 Fault Found:
    01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
    35-00 - -
    I'm particularly confused by the key signal code, what exactly does that mean?
    any help appreciated
  2. dsmclark40v
    dsmclark40v Member
    744
    The first one could be something to do with the coil behind the ignition for the immobiliser. I think there is something where the wiring gets streched or something. does the car fail to start sometimes and you get a flashing key on the dash?
    I get the central locking pump run time exceeded (likely leak) some times but i clear it and it won't come back for months. i think it just needs the tubes from the pump pushed back down a bit or something
  3. DPM
    DPM Site Sponsor Site Sponsor
    5,056
    220
    I always get that 'Central Locking Pump' fault code... the little ******!
  4. rodenal
    1,992
    Yeah i wondered if the key one was just that immobilizer thing, happens occasionally - take the key out open n close the door and away i go.
    So the central locking pump isnt anythign to bother about then? i've noticed that if i lock the doors from inside then the passenger cant get out just by pulling the handle - needs me to unlock it from the switch again. Not that it bothers me enough to actually replace anythign lol
  5. Uwe@Ross-Tech
    Uwe@Ross-Tech Member
    130
