Idea of what can be done....
Louis Cronin Apr 30, 2010
  1. Louis Cronin
    Louis Cronin Member
    67
    Hi guys,
    Just purchased a A4 Cab (B6) and wondered what could be done using VAG COM?
    I use to play around with it on my Golf MK4 and wondered what could be done on the A4?
    Im just waiting for my activation code to come back (long story, Windows crashed on my Mac and had to reinstall it all)
    I know you can make the needles light up, turn the volume up on the parking sensors
    Anything else?
  2. Louis Cronin
    Louis Cronin Member
    67
    Anyone?
  3. bearthebruce
    bearthebruce Ross-Tech, LLC
    343
    21
  4. Louis Cronin
    Louis Cronin Member
    67
    Hi Bruce,
    I did have a look but the values in the softcode do not match what i have. Bit stuck.
    Can you help?
  5. bearthebruce
    343
    21
    Post an Autoscan of your car. Define what you want to change from the list of things on the page that I listed in my last post. Once I know what you want to attempt and what the present coding is, I should be able to suggest further changes.
  6. Louis Cronin
    Louis Cronin Member
    67
    Mode 1: Pointers lit all the time
    selective locking 1 door/all doors
    locking via speed
    horn sounds when lock with remote
    The above are the things i would really like to activate. Can they be done on a B6 cab?
    i will post a scan asap
    Thanks Bruce
  7. Louis Cronin
    Louis Cronin Member
    67
    VCDS-Lite Version: Release 1.0
    Sunday, 09 May 2010, 09:02:24:38823
    Chassis Type: 8H - Audi Cabrio B6/B7
    Scan: 01,02,03,08,09,0F,11,15,16,17,18,26,36,37,45,46,55,56,57,63,65,67,73,75,76,77
    Address 01: Engine Labels: 06C-909-559-ASN.LBL
    Controller: 8E0 909 559 H
    Component: 3.0L V6/5V 0003
    Coding: 0011584
    Shop #: WSC 00672
    1 Fault Found:
    19497 - Powertrain Databus: Implausible Engine Temp. Message from Inst. Panel
    P3041 - 004 - No Signal/Communication - Intermittent
    Readiness: 0000 0000
    Address 08: Auto HVAC Labels: 8E0-820-043.LBL
    Controller: 8E0 820 043 L
    Component: A4 Klimaautomat 1116
    Coding: 00100
    Shop #: WSC 00672
    2 Faults Found:
    00735 - Potentiometer in Positioning Motor for Air recirculation Flap (G143)
    30-10 - Open or Short to Plus - Intermittent
    01794 - Control Module - Incorrect Chassis (VIN) Number
    35-00 - -
    Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.LBL
    Controller: 8E0 907 279 E
    Component: int. Lastmodul RDW 0305
    Coding: 00001
    Shop #: WSC 00000
    1 Fault Found:
    00985 - Right Tail Light (M2)
    57-00 - Electric Circuit Failure
    Address 15: Airbags Labels: 8H0-959-655-84.LBL
    Controller: 8H0 959 655 B
    Component: Airbag 8.4EC 1015
    Coding: 0011104
    Shop #: WSC 00672
    2 Faults Found:
    00474 - Control Module for Immobilizer
    000 - - - Intermittent
    Address 17: Instruments Labels: 8E0-920-9xx-8E2.LBL
    Controller: 8H0 920 980 F
    Component: KOMBI+WEGFAHRS. RB4 D15
    Coding: 00401
    Shop #: WSC 00001
    18534 AUZ6Z0B0312364
    2 Faults Found:
    01039 - Coolant Temperature Sensor (G2)
    01176 - Key
    07-10 - Signal too Low - Intermittent
    Address 45: Inter. Monitor Labels: 8E0-951-177.LBL
    Controller: 8H0 951 178
    Component: Innenraumueberw. 0211
    Coding: 00001
    Shop #: WSC 00000
    4 Faults Found:
    01350 - Alarm via Theft Warning System; Rear
    43-00 - Closed
    81-00 - Open
    01349 - Alarm via Theft Warning System; Front
    43-00 - Closed
    01838 - Transceiver Module 2 for Interior Monitoring (G305)
    27-10 - Implausible Signal - Intermittent
    Address 46: Central Conv. Labels: 8E0-959-433-MAX.LBL
    Controller: 8H0 959 433 D
    Component: Komfortgerát T3B 1210
    Coding: 06795
    Shop #: WSC 00672
    3 Faults Found:
    01616 - Signal Wire to Interior Monitor
    49-10 - No Communications - Intermittent
    01370 - Alarm triggered by Interior Monitoring
    35-00 - -
    01331 - Door Control Module; Driver Side (J386)
    80-10 - Single-Wire Operation - Intermittent
    Address 56: Radio Labels: Redir Fail!
    Controller: 8E0 035 192 B
    Component: Radio BNO 0001
    Coding: 00207
    Shop #: WSC 00081
    1 Fault Found:
    00856 - Radio Antenna
    44-10 - Short Circuit - Intermittent
    End --------------------------------------------------------------------------------------------------
  8. Louis Cronin
    Louis Cronin Member
    67
    is my car falling apart? lol
