ICE install whistle
QUATTRO_REP Jan 3, 2007
  1. QUATTRO_REP
    QUATTRO_REP Diesel Power!
    229
    Hi all and happy new Year!!:thumbsup: :o.k:
    Jus a quick question, just fitted an amp and sub to the OE headunit in my A3 using the original loom from the crappy sub, just i get an annoying whistle thro the speakers now when any other electrical stuff is on, and is linked to the engine revs, so prob gettin interferiace from the electrical system some where.
    any ideas? soloutions?
  2. rodenal
    rodenal Active Member
    1,992
    Maybe try just putting better insulation round the audio cables?
  3. Randomjim
    Randomjim Active Member
    2,752
    You might need a ground loop isolator to cut out the interferance. But what did you mean by the original loom from the sub?
  4. jojo
    28,929
    3,583
    Check the earth on the subwoofer is a nice clean contact, I had the alternator whine when I had my Andymac stealth sub fitted, so had a ground loop isolator fitted which cured my problem.
  5. QUATTRO_REP
    229
    might be the grounding, i jus screwed it onto an exsisting bolt and didnt bother sanding away any paint.
    by the original loom i mean from the OE Sub, the pre-outs from the old sub is a simple plug conector that andymac gave us the pin out diagram. which was very usefull. i used the pre outs to drive the new amp.i used to drive my new amp.
    where can i get a ground loop isolator from?
  6. jojo
    28,929
    3,583
    I got mine from Halfords for around 12 quid, it goes onto the pre-out jacks on the amp side, any decent Audio store should stock this item.
  7. QUATTRO_REP
    229
    cheers mate, i'll have to go get one. just googled it and sounds like whats happening.
