I want a Rotary machine....
jammy84 Aug 24, 2011
  1. jammy84
    jammy84 New Member
    Can anyone recommend a good rotary machine polisher? I currently have a Kestrel DA but it is so annoying, too vibraty, and takes so long to polish what you can do with a rotary takes 5 times as long.
  2. John @ PB
    John @ PB Member
    360
    There's no way a DA takes 5 times as long as a rotary - something wrong with technique and application there; maybe pads or polishes?
    Yes, a DA vibrates more due to its nature but you should only be machining your car, at most, once a year anyway so it shouldn't be a huge issue; the Kestrel is well within health and safety tolerances.
    Also, bear in mind the rate at which a rotary will remove paint and the increased risk of burning through/strike through.
    You should use a paint depth gauge with any machine polisher but they are vital with a rotary.
    If you do want to go to a rotary, we rate the Makita above any other; Makita 9227CB Rotary Machine Polisher | Makita Car Care & Detailing Products yes, it's a little bit heavier than some but it's still, in our view, the best on the market.
    I think you'd be best to look at your pad and polish choice (I assume you're working on an Audi) and run through your polishing procedure first though and we can maybe spot something there.
  3. FranA3
    FranA3 FMDETAILING Regional Rep Site Sponsor Gold Supporter Audi A3 Team Brill Red
    7,245
    340
    as john said a da should be plenty for normal use a rotary can do alot of damage if not used correctly weather its burning paint or causing swirls/maring/halograms in the paint or worst case burn through ive seen it alot of times in my time use with caution , try using a different pad/polish combo for better results
