I Think my Climate Control Unit is dead
imported_Astwell Sep 21, 2004
  1. imported_Astwell
    imported_Astwell Guest
    I Think my Climate Control Unit is dead, I have a 95 A4, Just got it 2 weeks ago. Had the Aircon Charged last night, as I was under the impression that was the problem, but it's not.
    It always puts out hot air and only out of the top and bottom vents. Also the Air cons Compressor doesn’t kick in (so i'm told).
    Do you think this is all down to the Climate control unit?
    Any help will be greatly appreciated
    Jamie /ubbthreads/images/graemlins/confused.gif
  2. audi5e
    audi5e Member
    809
    what can you see on the screens when you try to use it?
    if the compressor is on then there should be an ice symbol at the bottom left.
    You can use the onboard diagnostics to check for errors. just press and hold the recirculate and the up arrow together to enter this mode. you should see 01c, then briefly press the recirc button again to get the reading. to move between items in the list use the temp plus and minus buttons.
    if you want the codes just pm me, and i will send them to you.
  3. foolish3uk
    foolish3uk Member
    455
    take it to your stealer and they can do a final control diagnosis on all teh motors and tell you what is and isnt working!
  4. imported_Astwell
    The Screens are constantly flashing, when I press the Aircon button the ice symbol only stays on for a second, same thing happens when I press the recirc button.
    I entered the onboard diagnostics and quickly got baffled /ubbthreads/images/graemlins/crazy.gif
    Confused Jamie
  5. imported_BkkS6
    imported_BkkS6 Guest
    I have had a slightly similar problem with my 95 S6. The ice symbol or AC or compressor would stay on briefly and cut off. Turned out the freon level was low, so I had it recharged. The problem did not go away, finally I discovered that the electric fan was not working half the time causing the AC system to heat up and consequently tell the AC system to kill the AC compressor.
  6. foolish3uk
    foolish3uk Member
    455
    if the screens are flashing then it probably wants basic settings done, however if you are turning the buttons on then they are cuting out then you have a bigger turkey to fry
  7. audi5e
    audi5e Member
    809
    I agree with foolish3uk, if the screens are flashing then it is probably the control unit?
  8. audi5e
    audi5e Member
    809
    another thing, if the outside temperature is below 5deg C then the compressor will not switch on unless you choose the window defrost switch. However the recirc button should still continue to operate as normal.
    Have an auto electrician / Audi check the problem for you.
  9. imported_Astwell
    Thanks for the advice, She’s going in to Audi next Thursday so I will get them to check it out then.
    I’ll let you know the outcome.
    P.S.
    I’m a vegetarian so there’ll be no turkey frying! Maybe a bigger nut roast to fry ………maybe not.
  10. audi5e
    audi5e Member
    809
    you could always cook the turkey anyway and send it this way.... :)
  11. imported_Astwell
    Northampton, England to Johannesburg! Hummmm maybe not!
  12. audi5e
    audi5e Member
    809
    it would probably be a bit leathery by the time it got here.... :)
