I think my car could be a helicopter!!
aythree Apr 19, 2009
  1. aythree
    aythree Guest
    I've got a factory fitted sunroof, electric tilt and slide.
    When it's fully open in the slide back position and I drive at anything over about 30-35mph I get what is probably the most annoying wind noise known to man!
    It sounds like a bassy fluttering sound, almost like a helicopter :confused:
    It blocks my ears in the same way as being on a landing plane or a London tube.
    It does my head in and is so bad that I just cannot drive with it open.
    Anybody else get this with theirs??
    And if so, any tips on stopping it?? (Apart from the obvious "keep it closed"!!)
    I've noticed that if I stick my hand out of the sunroof it either stops or greatly reduces the noise. However, for obvious reasons this solution isn't feasible!! :)
  2. MintyS3
    MintyS3 Works 60% the time, Everytime.
    1,580
    It shouldnt do that. I wonder if the wind deflector at the front of the sunroof is coming up? It should be spring loaded and come up automatically when you open the sunroof.
  3. gixxer600k4
    gixxer600k4 Member
    692
    this noise is the air pulsating. like if you only have one window open it will do it, this is because there is a rush of air going into the car but nowhere for the air that is already in car to go. what u need to do is open both front windows slightly n it should go. its all about pressure, and when air rushes in, there is more air pressure inside the car so it pushes air out sunroof n then air goes back in, out,in,out n so on, n that is what causes that pulsating noise!
  4. mattfinn
    mattfinn Smoking is good for you
    830
    12
    You tried having one window open to equalise the pressure?
  5. B17AVM
    B17AVM The Whoa
    107
    My bro's A2 chopper does the same when the fronts are open a tad.
    He's not too fussed about it but it does sound really weird! lol.
  6. gixxer600k4
    gixxer600k4 Member
    692
    all cars will do it, go for a drive and open just one window, it should pulsate again, and then open another window n it will go! same theory about sunroof. but as said below, there should be like a flap/diffuser which will break up the air coming into car and decrease flutter!
  7. NHN
    29,298
    1,701
    The sunroof has 2 positions when opened via sliding, the 1st position when dial is turned to to the 1st stop position it goes 3/4 way back & this usually causes the noise, if you then turn the dial more & hold it there as its sprung loaded it will go all way back, this usually stops that noise
    also just check as already stated the deflector is coming up ok & also as advised if still pees you of just open window a little.
  8. aythree
    aythree Guest
    Thanks for the suggestions guys!
    The wind deflector does come up, was the first thing I checked.
    The noise seems to happen in all positions... with the sunroof partially and fully open.
    Don't think I've tried opening window(s) yet to see if it stops the noise though.
    Will give it a go. :icon_thumright:
    Seems a shame that I have to have the windows slightly open whenever I want to have the sunroof open though.
    Oh well, I guess it's that or go back to sticking my hand out of the roof!! :)
  9. NHN
    29,298
    1,701
    Or not open the sunroof :undwech:
    These bloody emoticons keep moving around the damn screen, the programmers did this on purpose
  10. aythree
    aythree Guest
    Ahem!! :)
    Anyway, all sorted now guys. Windows left slightly open and noise has gone.
  11. NHN
    29,298
    1,701
    lmao
  12. royjk
    royjk Member
    167
    Or buy a cabrio, don't get this problem at 80mph
  13. RobinA3
    RobinA3 Well-Known Member
    1,826
    45
  14. mac1403
    mac1403 Member
    972
    There is supposed to be a comfort setting on them. This equates to about 3 notches closed from fully open. If you close the sunroof 3 notches you should have a massive improvement and your roof still open. Other than that its crack the rear windows
  15. mattfinn
    830
    12
    Winner! My first ever useful post on ASN i think hahah!
