I think its done!
unikarl Jun 14, 2011
  1. unikarl
    unikarl Member
    367
    Well, I've finally got all my parts together for my xenon conversion and its all installed... My to do list for the car has a cross through everything... I never thought I'd see that happen!
    Quick pic of the work in progress!
  2. razza1
    razza1 Well-Known Member
    3,063
    820
    never say never ;) get a cupra splitter on it :)
  3. unikarl
    unikarl Member
    367
    Na.....Cant get over speed bumps as it is!
  4. dubdemand
    dubdemand VAG Addict
    405
    Sounds like it's time to sell up and start a new project then lol
    How easy was it to install? Does everything work and do you have auto levelling? Also, on HID cars there is an extra dial in the car to allow you to turn on DRLs. Have you got this fitted too?
  5. Triple.O.G
    Triple.O.G Active Member
    1,113
    Looking good old lad. i wish i could affordt the time, effort and cash to do this myself as they just look so mean.
  6. chrisa4quat
    chrisa4quat Active Member
    970
    What parts do you need to do this? i have a HID kit but would like to retro fit xenon's to my DTM. Can't believe it didn't have them from stock. Altho it hadn't got cruise, armrest or RNS-E, which are on list. well cruise and armrest done :)
  7. Paullie
    Paullie Banana Menace! VCDS Map User
    2,076
    288
    Nice one Karl, the Xenons look great! I remember trying to source BiXenons for the VXR and lots of the guys on VXRO said it would cost me a fortune to do and that I probably wouldn't get them to work. Only cost me £250 in the end including my lights and it paved the way for lots of peeps wanting them on their non-Xenon Astras. So, what's next for you, now you've crossed off everything on your to-do list? New car? New list?
  8. unikarl
    unikarl Member
    367
    The install was pretty easy. Changing the lights is a doddle as is fitting the wiring adapter. Just needed them coding to the car and as I didn't have vag com I got hazzy days to do it. He was really helpful. The DRL's are always on at the min as I don't have a switch but I'm going to get the switch unit that has the coming home light feature too as I have the autodimming mirror so I also have the light sensor.
    Everything works spot on and the beam is far better than the halogens.
  9. unikarl
    unikarl Member
    367
    Thank you!
    I remember you trying to source the lighst for your VXR too but you got the last set from the cheap site you found. I ended up leaving mine as standard.
    Next is keep it clean and running right I guess...Maybe a couple of little things here and there but overall I'm a happy bunny now.
  10. Paullie
    2,076
    288
    Great stuff, Karl! Car looks lush, Xenons really give the front end a mean, moody look. :)
  11. chrisa4quat
    970
    Has anyone got a part number list at all? :happy:
  12. Sam W
    Sam W Member
    175
    What's with everyone jumping from Astras to Audis! I used to have one too! :laugh:
    Top modding Karl, glad you're happy with it all :)
  13. unikarl
    unikarl Member
    367
    Sorry mate, all the part numbers are under the lights and that would mean removing them again. I'll try and put you a list together though from my invoices.
  14. chrisa4quat
    970
    I had an astra coupe 888 edition also :arco:.
    As for part numbers from invoices, that would be great
  15. unikarl
    unikarl Member
    367
    OK, here are a few part numbers but bear in mind that I used a mix and match of different versions.
    Central Electronic modeule is 8E0 937 279N
    O/S headlight 8E0 941 004AG, Ballast 8E0 941 329A
    N/S Headlight 8E0 941 029AT, Ballast 8E0 907 391B
    The xenon tubes needed are D1S and the kufatec wiring harness is also needed.
  16. gary3306
    gary3306 Active Member VCDS Map User
    989
    40
    Not quite, I had a Vectra VXR :sm4:
  17. hardcorism1983
    hardcorism1983 New Member
    10
    Hi unikarl, pretty sure I have put an offer up on eBay for you old lights. I'm wanting to get xenons too but they can wait for a while. The clear indicator mod will do for now.
  18. Phantom_A4
    Phantom_A4 Member
    563
    Great job, loving your plate too! :D
