I stripped my Forge DV down as i wasnt sure if it was leaking... Advice needed please
S3 Paul Jan 19, 2013
  1. <tuffty/>
    21,688
    4,119
    The redesigned piston is to fix the leak issue.. seems they have reduced the internal volume a bit too
    There is no need for a stiffer spring as the spring is only used as a return spring not a mechanism for holding it shut... the shim is to reduce the pistons internal volume making it faster to react and the green spring should be all thats needed for the valve to operate normally... this is relevant for the older design but arguably not so much on the new design...
  2. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Did you see the pics? it has greatly reduced the Volume.... there is no need to shim it trust me...
  3. <tuffty/>
    21,688
    4,119
    I didn't notice but I can see what you mean... use of a shim still stands if using a previous version of the piston though...
  4. vrbob
    vrbob Thats no Moon, Thats a space station!
    2,375
    171
    Cool well will see if forge send me the redesigned piston and then I will give it a service put the new piston and swap back to the green spring
  5. s3dave
    10,110
    736
    Yeah its almost flush with the spring seat now..
  6. vanilla_ice
    vanilla_ice Active Member
    714
    I can see Forge getting a lot of emails about this. vrbob, are you expecting to pay for a new piston?
  7. <tuffty/>
    21,688
    4,119
    Before everyone has a panic.... this...
  8. vrbob
    2,375
    171
    If I can then yes that is what would be ideal, There is a link to the service kit which can be found here Forge Motorsport | Alloy Fabrication its £15
    But I am going to see if I can get just the piston FOC as this is the re designed bit and probably the only bit I really need as such
  9. S3 Paul
    S3 Paul Well-Known Member Regional Rep
    2,825
    107
    Dave, from the picture it looks like the seal is trapped / secured in place by the end of the piston that looks to be screwed on from the screw head i can see inside?
  10. vrbob
    2,375
    171
    Had a reply back from forge saying I could buy the service kit from them :(
    They also say that the new piston design is only for the super size DV, is that right as the pic that S3 Dave posted earlier comparing the new vs old that looks identical to my current piston. so have sent them the pic as an attachment to see if that is correct or not.
    Vex182 likes this.
  11. <tuffty/>
    21,688
    4,119
    Ok... the problem here is that while not ideal the design is not an actual failure... I cannot see Forge replacing every single piston they have ever made because it could potentially leak a little... at least Forge have recognised that the design needs improving and have taken steps to do so...
    Forge valves have been around for donkeys years and while I have no doubt there has been a degree of leakage from some of them over the years its never presented itself as a real world problem... I personally think the whole running too stiff a spring thing is a bigger issue myself... I for one was under the impression the springs rate needed to be higher to hold it shut but I realise now this is not the case and have seen it for myself how much using a lighter spring and reducing piston volume can improve the valves overall performance....
    Lets not forget these parts still wear out over time... a lot of the cases where leaking is an issue are probably just down to wear... this is a soft alloy after all... the wear visible on the side of the OP's piston was from rubber o-rings!... it does happen...
    As I have already mentioned a couple of times the ECU will compensate for small leaks and I very much doubt there is any real world performance hit under normal circumstances (this is too subjective to be definitive of course)...
    The service kits are relatively inexpensive and something that needs to be done once in a while... if you have obvious wear and the grease has mostly gone then all you can really expect from Forge is to make sure the service kit contains the latest revision of the piston...
  12. s3dave
    10,110
    736
    Possibly Paul, i didnt bother poking around, im sure it will be fine..
  13. S3 Paul
    2,825
    107
    Good news !
    Royal mail managed to finaly find my Package from Forge
    So... i tested the Forge DV as it was... ( sorry no gauge as i had to give the correct pump back ) so i rigged up my cycle pump...
    Just to be clear i did locate the clamps correctly before the test was done. i just pushed them on to show what set up i used.
    one pump... Bubbles. as expected, i had lapped the old piston in but either i stopped too soon or ... the Orings had seen better days.
    I stripped the valve down cleaned it completely, Sealed the side port thread ( as this was leaking too on the bubble test ) i used "hondabond" high temp silicone based gasket sealent, when that had cured i rebuilt the valve with the new O rings and piston using the suplied grease as i went...
    Back to the sink to test for bubbles... NONE. as i said i have no gauge to hand today but where the old piston leaked as i finished the first full pump this new set up was holding at three pumps. until the hose i had on the side port blew off.
    In my eyes thats a massive improvement . i retested and left it at two pumps and left it under water... no leaks.
    Everything moves as it should so i know its not stuck but it seals ! thats for sure...
    This is the old piston after i lapped it in... but it leaked far too easy
    This is what came in the kit.
    Many thanks to Forge
  14. A3 T
    A3 T Lord Of The Rings
    1,077
    15
    Well done mate :thumbsup:
  15. vrbob
    2,375
    171
    Brucie Bonus :)
    Got an email form Forge this morning to say they are gonna send me out one of the new pistons.
    So once it arrives I will give the 007p a nice service and upgrade the piston. I will also swap my current yellow spring setup to a green spring and a shim and see how this performs :)
  16. S3 Paul
    2,825
    107
    I think there is no need for the shim in the new piston. Tuffty mentioned it further up the thread.
    Im running a yellow spring and the car is fine. Now holds bang on whatever boost im at ( say if i put the throttle down and hold it at 10 psi it stays bang on there until i move my foot up or down) it used to drop 3 or 4 psi .
    The "dumping" sound is a crisp "tish" rather than the chatter i was getting.
  17. badger5
    9,556
    2,028
    sounds like decent progress
    well done all
  18. vrbob
    2,375
    171
    Cheers for the info mate, I have the full spring kit as I bought it off ebay last year. So will stick with the yellow spring and just give it a good service instead when fitting the new piston.
  19. Prawn
    11,608
    3,584
    Excellent news Paul, Very glad to hear it.
    Now, I must get myself the new piston!
  20. vrbob
    2,375
    171
    New piston arrived this morning, Cheers Forge :)
    So as I had an hour spare this afternoon I grabbed my service kit (received last year) and stripped down the 007p.
    Took all the o rings out and gave it a good clean all round removing the old (now black) grease.
    once clean I used the nice pink grease on all the clean o rings and re seated them all.
    Gave the new design piston a light greasing and then re-seated that. Don't over grease it it only needs a very light coating.
    All back together with the yellow spring still in place and did the finger test (push up piston, cover to nipple with finger, release piston, it should drop about 5mm and then hold in that position until you release your finger on the top nipple and it should then snap closed).
    Not done any real world testing but will see how it feels during my commute to work tomorrow.
  21. A3 T
    1,077
    15
    Swapped my bailey DV30 for the forge 007p and fitted the new style piston today.
    All seems good so far :)
  22. s3clarke
    s3clarke Money grabbing s3!
    677
    35
    Fitted my oem dv the other day, and went for a proper drive yesterday, what a transformation, boost is so much stronger, my forge must have been leaking bad for a long time. oh well I sold it on eBay the other day and I wont miss it lol
  23. vrbob
    2,375
    171
    New piston seems to work well, didn't get much "testing" done on my way to work (damn those other cars on the road)
    But boost seems good so will maybe do some logging later on.
    So if you have a 007p rather than flog it and buy another get yourself a service kit and ask for the new piston as this may well solve any issues you had and maybe forge will help out FOC if not its only £15 to get it back up and running again. Plus servicing the DV is I good idea too to keep optimum operation.
  24. S3 Paul
    2,825
    107
    Well thats prety much why i contacted Forge...
    I thought spend on a stock DV to cure the issue ( by removing it ) or see if they could help and to be fair... Yes the DV was pricey when i bought it... but to send me the internals free. Top service and problem solved.
  25. vrbob
    2,375
    171
    Exactly, I spent near enough £100 on my 007p and spring kit etc so why not get it running correct rather than sell for a loss and buy another DV.
  26. A3 T
    1,077
    15
    I've got to say this forge valve isn't as loud as my old bailey dv30.
    Not sure if its the new piston or just how these forge valves are?
  27. dre_S3
    dre_S3 Member
    756
    39
    i find my standard Bosch valve is louder then my old 007 the answer I am looking for is how much can the Bosch take ? as I have a brand new 008 DV that I have not fitted, will I need it for when I get my car mapped ? I have sold my 007 by the way and I am using my Bosch at the mo with no problems I find it better the my 007 to tell the truth
  28. Jason.s
    Jason.s Active Member
    2,879
    348
    30psi has been tested and held fine.
  29. dre_S3
    dre_S3 Member
    756
    39
    So do I really need the 008 for when I get the car tuned ? are the diaphragms in the Bosch strong enough to trust on a tuned s3 ?
  30. dre_S3
    dre_S3 Member
    756
    39
    Double post stupid iPhone :keule:
  31. Jason.s
    2,879
    348
    You dont NEED it no but it`ll outlast the OEM plastic item.
  32. Gops
    3,198
    666
    Just thought I'd say, I recieved my forge piston today FOC! They have been great with service! Thumbs up to them! :thumbsup:
