i really wish i didnt purchase this vcds cable :/
monopole Jan 17, 2013
  1. monopole
    monopole Well-Known Member
    1,154
    470
    (again.... only kidding Nige)
    So my next questions is, what does this mean:-
    Address 01: Engine (CDL) Labels: 06F-907-115-CDL.clb
    Part No SW: 8P0 907 115 AP HW: 8P0 907 115 B
    Component: 2.0l R4/4V TFSI 0010
    Revision: 5BH21--- Serial number: AUX7Z0L7FNG0BP
    Coding: 0103000C1C0F0160
    Shop #: WSC 06314 000 00000
    VCID: 80093D5BD3E6191E08D
    1 Fault Found:
    000256 - Mass Air Flow Sensor (G70)
    P0100 - 004 - Supply Voltage - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 2
    Fault Frequency: 2
    Mileage: 4246 km
    Time Indication: 0
    Freeze Frame:
    RPM: 0 /min
    Load: 0.0 %
    Speed: 0.0 km/h
    Temperature: 73.0°C
    Temperature: 57.0°C
    Absolute Pres.: 1020.0 mbar
    Voltage: 11.938 V
    Is it relative to me having an APR St1 remap AND a Nuespeed P-Flo installed?
    Didn't notice any running problems, fuel efficieny is a good as ever, I was out looking at tweaking the DRL's/auto light sensitivity and first things first ALWAYS run a scan and this pops up.
    Cheers guys
  2. mike foster
    3,967
  3. hades-
    9,482
    646
    you may need a new maf
  4. monopole
    1,154
    470
    cheers mike, I had seen that but like you say, don't know what it means.
    I have no idle/running issues and the car has only done a little over 2500miles so surely not a faulty MAF.
    I suspect a wiring issue to the sensor but had a look and it all looks secure and in place.
  5. hades-
    9,482
    646
    unplug the wireing clean plug back in
    clear codes
    and rescan after a drive.
  6. monopole
    1,154
    470
    will do later today
  7. Lewbo
    Lewbo Well-Known Member
    1,275
    106
    Is the maf in the correct way I know most intakes only go in one way but may have installed the wrong way by accident so maybe worth a quick look.
  8. monopole
    1,154
    470
    yeah, when I fitted the Nuespeed, the MAF only went in one way
  9. RedDejavu
    RedDejavu Well-Known Member
    1,806
    337
    try to fit standard intake back on maybe and see if the issue is still there? Looks like MAF wiring problems tho
  10. monopole
    1,154
    470
    ooooooooooooooooooooooookay
    so went out, removed MAF, looked immaculate, cleaned connector, checked wires, all intact and look in good condition. Refit and launched VCDS
    1st cleared all current DTC's
    2nd ran scan
    3rd got pretty miffed......
    2 Faults Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Mileage: 4246 km
    Time Indication: 0
    Freeze Frame:
    RPM: 0 /min
    Load: 0.0 %
    Speed: 0.0 km/h
    Temperature: 73.0°C
    Temperature: 57.0°C
    Voltage: 11.938 V
    049489 - No Communications with Airbag Control Module
    U0151 - 008 - - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 4246 km
    Time Indication: 0
    Date: 2013.01.08
    Time: 15:19:29
    Freeze Frame:
    RPM: 0 /min
    Load: 0.0 %
    Speed: 0.0 km/h
    Temperature: 66.0°C
    Temperature: 56.0°C
    Voltage: 11.938 V
    Readiness: 0000 0000
    ho hum
    full SCAN:-
    Thursday,17,January,2013,13:11:23:58778
    VCDS Version: Beta 12.10.2 (x64)
    Data version: 20121222
    Chassis Type: 7N0
    Scan: 01 02 03 08 09 10 15 16 17 19 22 25 2E 37 42 44 46 52 55 56
    62 72 77
    VIN: WAUZZZ8P0DAXXXXXX
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    22-AWD -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    2E-Media Player 3 -- Status: OK 0000
    37-Navigation -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    55-Xenon Range -- Status: OK 0000
    56-Radio -- Status: OK 0000
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    2 Faults Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Mileage: 4246 km
    Time Indication: 0
    Freeze Frame:
    RPM: 0 /min
    Load: 0.0 %
    Speed: 0.0 km/h
    Temperature: 73.0°C
    Temperature: 57.0°C
    Voltage: 11.938 V
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 4246 km
    Time Indication: 0
    Date: 2013.01.08
    Time: 15:19:29
    Freeze Frame:
    RPM: 0 /min
    Load: 0.0 %
    Speed: 0.0 km/h
    Temperature: 66.0°C
    Temperature: 56.0°C
    Voltage: 11.938 V
    Address 02: Auto Trans Labels: 02E-300-0xx.lbl
    Part No SW: 02E 300 014 S HW: 02E 927 770 AL
    Component: GSG DSG AG6 512 3527
    Revision: 05551213 Serial number: 00001208111287
    Coding: 0000020
    VCID: 224DD7D3FD2A6B0EBE9
    No fault code found.
    Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
    Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
    Component: ESP MK60EC1 H31 0152
    Revision: 00H31001
    Coding: 1642801249250001681101E7921B0081390000
    Shop #: WSC 06314 123 12345
    VCID: 7DF7C4AFE414F4F6E3B
    Address 08: Auto HVAC Labels: 8P0-820-043.lbl
    Part No SW: 8P0 820 043 BN HW: 8P0 820 043 BN
    Component: KlimavollautomatH09 0180
    Revision: 000081 Serial number: 8P0820043BN
    Shop #: WSC 00000 000 00000
    VCID: 79FFD0BF303CC8D6CF3
    Address 09: Cent. Elect. (J519) Labels: 8P0-907-063.clb
    Part No SW: 8P0 907 063 N HW: 8P0 907 063 N
    Component: BCM PQ35 M 111 0715
    Revision: AM111715
    Coding: 4E000A2FA005F0C0E07041E0010009D4427E2BAA307DD928E40008840040
    VCID: 3F8B7EA7AE9826E6B17
    Subsystem 1 - Part No SW: 8P2 955 119 F HW: 8P2 955 119 F Labels: 1KX-955-119.CLB
    Component: Wischer AU350 H11 0050
    Coding: 00DD13
    Subsystem 2 - Part No SW: 8K0 910 557 HW: 8K0 955 559 A Labels: 8K0-955-559.CLB
    Component: REGENLICHTSEN H04 0003
    Coding: 02212D
    Subsystem 3 - Part No: 8P0 951 177
    Component: Innenraumuebe H04 0020
    Subsystem 4 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HO H05 1501
    Subsystem 5 - Part No: 1K0 907 719 C
    Component: Neigungssenso 005 0003
    Address 10: Park/Steer Assist (J446) Labels: 8P0-919-475-7X1.clb
    Part No SW: 8P0 919 475 M HW: 8P0 919 475 M
    Component: PARKHILFE 4K H01 0140
    Revision: 11001001 Serial number: 36861221903652
    Coding: 000103
    VCID: 4899657BFB56615E00D
    Address 15: Airbags (J234) Labels: 8P0-959-655-10.clb
    Part No SW: 8P0 959 655 S HW: 8P0 959 655 S
    Component: Airbag AU1042 H10 0250
    Revision: -------- Serial number: 003JU0089PKS
    Coding: 30314238303830303037554A305238503053
    ASAM Dataset: EV_Airba10AURB4 001001
    ROD: EV_Airba10AURB4.rod
    VCID: 52AD4713050ADB8E6E9
    Crash sensor for side airbag; driver side:
    Serial number: 3572DRB40000ECB490B4
    Crash sensor for side airbag; passenger side:
    Serial number: 3582DRB40000ECA88264
    Crash sensor for side airbag; rear driver side:
    Serial number: 35128RB400006D14B33G
    Crash sensor for side airbag; rear passenger side:
    Serial number: 35228RB400006D1491CM
    Crash sensor for front airbag; driver side:
    Serial number: 35547RB400006D39710J
    Crash sensor for front airbag; passenger side:
    Serial number: 35647RB400006D3AB9A0
    Address 16: Steering wheel Labels: 8P0-953-549.lbl
    Part No SW: 8P0 953 549 K HW: 8P0 953 549 K
    Component: J0527 H38 0070
    Coding: 0014142
    VCID: 46856B433142772EF21
    Subsystem 1 - Part No: XXXXXXXXXXX
    Component: E0221 H06 0030
    Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
    Part No SW: 8P0 920 983 H HW: 8P0 920 983 H
    Component: KOMBIINSTR. VDO H03 0380
    Revision: D0H03005 Serial number: 2247L005000214
    Coding: 0257428
    VCID: 3F8B7EA76E9826E6B17
    Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
    Part No SW: 7N0 907 530 R HW: 7N0 907 530 H
    Component: J533 Gateway H42 1632
    Revision: H42 Serial number: 250612F6001220
    Coding: 352103
    Address 22: AWD Labels: Redir Fail!
    Part No SW: 0BR 907 554 C HW: 0BR 907 554 C
    Component: Haldex 4Motion 3018
    Coding: 0000005
    VCID: 45876C4F0C447C36FBB
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    Revision: D0H03005 Serial number: AUX7Z0L7FNG0BP
    Address 2E: Media Player 3 (R199) Labels: 8T0-035-785.clb
    Part No SW: 8P0 035 785 HW: 8P0 035 785
    Component: SG ext.Player H08 0100
    Revision: 00000000
    Coding: 020202
    VCID: F4E1618B575E35BE1C5
    Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
    Part No SW: 8P0 035 193 G HW: 8P0 035 193 G
    Component: RNS-E PU EU H07 0220
    Revision: 0000013S Serial number: AUZBZ7MD215460
    Coding: 0209725
    Shop #: WSC 18990 000 10485
    VCID: 3461218B57DEF5BE5C5
    Address 42: Door Elect, Driver Labels: 8P0-959-801-MAX3.lbl
    Part No SW: 8P0 959 801 P HW: 8P0 959 801 P
    Component: Tuer-SG H04 0101
    Coding: 0000692
    VCID: 4899657B3B56615E00D
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K0 909 144 P
    Component: EPS_ZFLS Kl. 234 3305
    Revision: 00H22000
    Shop #: WSC 02069 000 90108
    VCID: 377B168746A81EA6797
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
    Part No SW: 8P0 959 802 P HW: 8P0 959 802 P
    Coding: 0000692
    VCID: 499F607F205C98561F3
    Address 55: Xenon Range (J431) Labels: None
    Part No SW: 8X0 907 357 C HW: 8X0 907 357 B
    Component: ****LWR12**** H02 0020
    Serial number: 120814-0002-006
    Coding: 1163A51010002400
    ASAM Dataset: EV_HeadlRegulBasic 005001
    ROD: EV_HeadlRegulBasic.rod
    VCID: 428D7753D56A4B0EDE9
    Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
    Coding: 0209725
    Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
    Part No SW: 8P4 959 801 F HW: 8P4 959 801 F
    Component: Tuer-SG H04 0050
    Coding: 0000144
    Shop #: WSC 06314 000 1012544
    VCID: 428D77531D6A4B0EDE9
    Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
    Part No SW: 8P4 959 802 F HW: 8P4 959 802 F
    Coding: 0000144
    VCID: 4383725702704206D5F
    Address 77: Telephone Labels: 8P0-862-335.lbl
    Part No SW: 8P1 862 335 A HW: 8P1 862 335
    Component: FSE_256x BT H44 0660
    Revision: 00000000 Serial number: 00000005569685
    Coding: 0011422
    VCID: 35671C8F5CA4ECB66BB
    End ---------------------------------------------------------------------
  11. monopole
    1,154
    470
    Nothing actually feels to be faulty.
    I shall live with these reported "intermittent faults" until something starts go give an actual "physical" symptom and then visit audi.
  12. Sevv
    Sevv Pushing the limits..
    1,324
    120
    mate give your MAF a clean thats what i did, and also clean the connectors make sure everything is bolted the way its supposed too , hoe everything works fine
  13. Cruiser89
    Cruiser89 Advanced In Car Tech Site Sponsor
    1,484
    222
    Maybe your S3 is a hypochondriac? Ha.
    I'm sure it's fine though bud. Probably something really simple. I don't get involved with the engine stuff on my car. lol
  14. RedDejavu
    1,806
    337
    try to see if MAF sensor gives any readings.
  15. NHN
    29,596
    1,782
    I'm curious how having the maf the wrong way round will affect the electrical connection, which is what this fault denotes.
  16. monopole
    1,154
    470
    after being irritated about the codes if anything, I went to the car today with Laptop and Cable in hands, I went into Module 1 and deleted the codes from there, ran a scan and showed all clear, no faults in any modules :D
    I shall check again in a few days but the generic "Clear all DTC's" doesn't actually clear them I think, so I've now learnt it's better to clear the codes from the relative module individually and rescan
  17. IceHanger
    IceHanger Active Member VCDS Map User
    340
    64
    I've also found that a couple of times:wtf: but thought meh they're cleared and not worried any further lol
