I Pod adaptor 2006 A4
Cjb Jan 11, 2013
  1. Cjb
    Cjb New Member
    14
    Im new to the forum got my A4 2.0 TFSI SE B7 about 2 months ago went from a 2000 mondeo to this and I think I'll be buying Audie's for the rest of my life now what a car very happy.
    Anyway I want to install a I pod adaptor but my stereo is single din and has an internal CD player and no option for cd 1 or cd 2. Does this mean a I pod adaptor will not work?
    I have looked at the connects 2 products and they all seem to use the cd changer connection so I'm presuming they don't work with out cd changer.
    Any help would be greatly appreciated thanks.
  2. phil_w
    phil_w Active Member VCDS Map User Audi A4 Audi Avant Owner Group S-line owners group Team Brill Red
    591
    54
    You'll be fine. The single din stereo will have the cd changer pins available on the back so iPod adapter will plug in with the right cabling (supplied with the device normally)
  3. Cjb
    Cjb New Member
    14
    That's great thanks I think ill order that 2mor sick of burning cd's.
  4. phil_w
    591
    54
    Just remember that no track names are shown just track 01,02 etc. don't want you being disappointed...
  5. Cjb
    Cjb New Member
    14
    Ya not bothered about the track names, just when I press the CD button I only have the option to play the cd in the stereo there is no cd changer option like CD01, CD02.
  6. bleedout
    bleedout Member
    69
    And ipod adapter or aux in cable will utilise the cd changer plugs in the back of our headunit.
    What you may have to do is have the coding for a cd changer turned on via VCDS. That way the headunit will treat the ipod like a multichanger seen as you dont currently have one fitted.
  7. Cjb
    Cjb New Member
    14
    Thanks Bleedout, have the coding for a cd changer turned on via VCDS is this something I could do or would i have to get an audio instalation pro to do it.
  8. Cjb
    Cjb New Member
    14
    Ok I have done some searching online and found that you need to get VCDS software and cable but it is possible. I don’t fancy spending 250-300 pound getting the gear and not being able to use it plus I don’t have the time. Is there anyone in the Liverpool area that does VCDS alterations for Audi A4 2006?
  9. phil_w
    591
    54
    Not convinced you'll need to do any coding. I've done quite a few in the past and no coding required- just physically plugging into back is enough...
  10. Cjb
    Cjb New Member
    14
    Thanks Phil I have ordered connects 2 adaptor cos either way ill need that, should be here Mon or Tue so ill see hope your right that would save a lot of messing.
  11. PetrolDave
    PetrolDave Well-Known Member
    1,559
    85
    +1
    The CD changer (or equivalent aux in or iPod adapter) just works without making any coding change.
  12. Jord_C
    Jord_C Active Member
    169
    Ive been looking into this also. But ive found that the Dension GW17AC1 looks to be a safe bet!
    Anyone on here got one installed with a concert II? As i can only really find people who have installed them with the symphony system! And was just wondering how user friendly it was to use, before i go blowing 130 on it! Lol.
    CjB, you will have to let me know how the install goes, as im curious as to what it will be like! :)
  13. Cjb
    Cjb New Member
    14
    No problem Jord_c it should be here 2mor so ill have a go at install 2mor evening and let ya know.
  14. Cjb
    Cjb New Member
    14
    Ok so I connected it all up connected my I pod and noting if you look at the picture below you can see CD on the screen this is all that comes up no CD1 CD2. Sorry about the size of the picture.
  15. phil_w
    591
    54
    If I remember correctly you press the cd button either twice or more to cycle into changer mode?
  16. Cjb
    Cjb New Member
    14
    Pressed the CD button twice,three times also held it in for a few seconds no joy.
  17. phil_w
    591
    54
    A quick test here:
    CD Changer Detection
    The following is the procedure on how to check if the radio detects an externally mounted CD changer.
    Turn off radio.
    While pressing and holding the MODE button, turn on radio.
    The display shows CONNECT if a CD changer is connected. Otherwise it shows NO CDC. This is a display-only mode. You cannot change any settings.
    When you are done, turn off radio, then turn it back on for normal operation.
  18. phil_w
    591
    54
    Whoops - no mode button...
  19. phil_w
    591
    54
    Right - done some digging and the consensus seems to be that some concert II headunits come precoded for cd changer connection and some don't , seemingly at random. I must have just been very lucky (5+ times)
    See link here - suggests that you may, after all need a VCDS friend for a 2 minute tweak...
    http://wiki.ross-tech.com/wiki/index.php/Audi_Radio_Generation_II
  20. Cjb
    Cjb New Member
    14
    Thanks phil_w VCDS it is then just my luck thanks for all your help greatly appreciated ill let ye know if I get it sorted.
  21. phil_w
    591
    54
  22. ajax1976
    ajax1976 Well-Known Member
    1,275
    656
    My car came with the Dension and concertII, I think its brilliant!! Dead easy to use, displays all track info on the dash, easy to scroll through playlists, tracks, artists from the steering wheel controls. Can't fault it to be honest, had a Xcarlink in my last car and its streets ahead of that.
  23. Jord_C
    169
    Thanks for your reply ajax! Looks like i will be getting one ordered in the next few weeks then! :-D
  24. AudiB7Jay
    AudiB7Jay Active Member Audi A4 S-line owners group Team Aruba Blue TDi saloon Manual
    448
    26
    Are these kits plug and play?
