My B8 a4 is "high" phone prepped and I just bought a cradle for my I-phone ,thing is can't get it to work in the cradle ,works fine off it thru normal bluetooth connection, am I missing something?
Are you turning the Blurtooth off when in the cradle? Some phones (my Nokia 6300 for example) use the cradle purely for the external aerial and charging.
The actual functionality still goes via Bluetooth.
If this isn't the case then I'm afraid I've no idea.
I wonder if you have a coding issue mate, cause it would seem its charging ok but cradle isnt active with car properly, it obviously discons the BT which would seem sensible if its in the cradle so probably switches profiles that would disable BT, assuming when you remove from cradle the BT auto switches on again, these are my thoughts but I dont know the B8 that well, but stands to reason & looking at coding & thinking outside the box it points me to this, example would be from this link below has options for enabling/disabling the cradle, do you have vagcom to check coding?
