- Joined
- Sep 14, 2008
- Messages
- 24,836
- Reaction score
- 6,078
- Points
- 113
- Location
- Wibbleton
- Website
- www.tuffty.co.uk
From that last log image, it looks as though IAT's aren't playing any part in your timing pull...
The log you did using block 031 doesn't show the excessive timing pull you are getting in the block 118 one you did. Maybe worth doing a few more runs using blocks 031, 115 and 020 and only post results of bad timing pull to see if the fuelling is an issue. Based on the originally posted image, fuelling looks fine and the timing pull is within normal params etc... on the logs where you are puling 5's there is no fuelling block so can't tell if the requested is fine but the actual is lean which would pull timing...
Out of interest, is the vacuum hose to the FPR ok? The original one is prone to disintegrating, check this at the inlet mani too, its in a really awkward place (just for fun) but if you have a leak here that will affect fuel mixture higher up the rev range.
