I need some help please with RNS-E retrofit...
Boosted Sep 18, 2011
  1. Boosted
    Boosted New Member
    21
    I have had a read through the forum but sadly am still confused when it comes to retrofitting an RNS-E unit.
    Couple of questions:
    1. What is the correct unit to use on a Mk2 TTS or can any unit be fully operational?
    2. What else do I need to install it, or is it simple plug and play? (I assume there needs to be a GPS receiver)
    3. Will my BOSE, Bluetooth and steering controls all be unaffected?
    4. Which unit should I go for?
    Thanks in advance
  2. s8craig
    1,753
    56
    You need a unit starting 8J0 to fit correctly.
    If you have BOSE and AUX then some wiring changes have to be made
    Bluetooth should be recoded to work correctly with an RNS-E
  3. Boosted
    Boosted New Member
    21
    Thanks mate!
    Will have a butchers...
