I just can't get used to the handbrake!
Ruthus_1 Jun 30, 2013
  1. Ruthus_1
    Ruthus_1 Member
    249
    46
    Hello
    I really love my new A3 but I really can not get used to the handbrake! My main problems come when I'm parked down hill and having to push the brake pedal to take it off meaning I can't get my byte to reverse backwards!
    Does anyone have any pointers for me?
  2. mjcourtney
    mjcourtney Well-Known Member Team Mythos Audi A4 Audi Avant Owner Group S-line owners group TDi
    1,690
    528
    Provided your seatbelt is on, and the drivers door is shut then the handbrake should automatically release without the need to push the foot break first.
    Try this: with the handbrake on put it in reverse, lift the clutch and apply enough acceleration in order to start moving the car back up the hill. You should find the handbrake releases automatically at the point at which the car starts to move.
  3. @udi A3
    @udi A3 Site Sponsor Site Sponsor VCDS Map User
    1,819
    197
    Also the level of revs needed to initially move the car has 3 settings iirc, and can be adjusted with VCDS. so if you feel like your slipping the clutch a lot before the brake releases you can soften the 'hold' with vcds.
  4. Ruthus_1
    Ruthus_1 Member
    249
    46
    Vcds?
  5. Ruthus_1
    Ruthus_1 Member
    249
    46
    My car seems to tell be to press the brake pedal even when I have my seat belt on and doors closed! Suppose only had it 2 weeks and will just take some getting used to!
    Thanks for your advice!
  6. @udi A3
    1,819
    197
    VCDS is a tool used with pc software to change a whole number of settings and features within your car ecu's. Also a host of other things including service resets, fault codes scanning, live data reading, and retrofitting. I remember playing around with a hire car as the handbrake seemed to hold on, and i changed the setting so just a minimal attempt to move allowed the brake to release. If your not sure see if there is somebody local with a similar system to have a look for you?
  7. TreborA4
    TreborA4 Active Member
    207
    Once you have got used to the electric hand brake, it's really great! I had it on my A4 Avant and now on my A3. I occasionally drive my wife's car, a Volvo C30 and, initially, I usually forget to take the normal handbrake off before moving forward! A bit embarrassing at traffic lights!
    As has been mentioned, you need your seat belt on (and drivers door closed!) for the handbrake to work automatically.
    Do you have Audi hill hold assist? This means I do not have to apply or release the handbrake at all! All automatic!
  8. coolguy
    coolguy Member
    144
    19
    Isn't this just the same without it as the handbrake will release automatically when you move?
  9. Ruthus_1
    Ruthus_1 Member
    249
    46
    No hill hold assist! Think I will just have to do some messing about to alter/get used to it!
    Thanks again for all the advice!
  10. TreborA4
    207
    With hill hold assist, there is no need to apply the brake yourself as it automatically comes on when stopped. Release is automatic as with brake without hill hold assist.
  11. coolguy
    coolguy Member
    144
    19
    So does that mean when you come to a stop, the handbrake is applied automatically as well as releasing?
  12. cemerson
    cemerson Well-Known Member Team Cosmos quattro Audi A3 S-line owners group TDi DSG
    4,578
    1,175
    It actually keeps the foot brakes held on without you having to hold the pedal down, but the effect is the same (other than the fact that your brake lights stay on). I think if you turn the engine off while hill hold assist is active the handbrake then comes on anyway.
  13. TreborA4
    207
    That's correct!
  14. Trebuchet
    Trebuchet Member
    57
    10
    Loving HHAssist.
    Firm press of brake pedal = HHA keeps foot brake on. Auto release at biting point
    Turn engine off or remove seatbelt whilst stationary = handbrake applied.
    Since turning it on I haven't touched either of the brake switches.
  15. Ruthus_1
    Ruthus_1 Member
    249
    46
    Well I'm all sorted now! Thanks again!
  16. coolguy
    coolguy Member
    144
    19
    Thanks cemerson, I wasn't sure about this feature and if a needed it.
  17. viperfire
    viperfire Active Member
    209
    43
    Hill hold assist i don't have but i find the car holds itself on a hill in traffic for say two seconds when release the foot brake. Not sure what the point of hha would be when it already does this?
  18. coolguy
    coolguy Member
    144
    19
    If that's the case, then that should be enough for me. Don't really travel up/down hills.
    Viperfire, can I ask what VED band (tax disc) is your car?
  19. number3
    number3 Active Member
    335
    27
    It holds automatically with HHD indefiently untill you pull away, so if in traffic on a hill you wouldnt have to keep putting your foot on the brake after the car releases after 2/3 secs. just an over and above the standard set up, i dont have it, but have had it on other cars and you do come to like it :)
  20. deci
    deci Active Member
    308
    126
    43
    I love the electronic handbrake. Always forget myself when in a car with a mechanical one now.
    I love the way it holds for a second or two on a hill start.
  21. A3sportbackMark
    A3sportbackMark Active Member
    711
    230
    43
    Glad you like it. I test drove a golf mk7 which had the hill assist feature and I thought is was great. Have ordered it for my Audi, but have to wait till sept!
    can the hill assist feature be fitted retrospectively, vcds?
