I have no brake lights
Niknak Mar 9, 2009
  1. Niknak
    Niknak Member
    867
    While driving home this evening ny dash board lit up like a christmas tree, thought oh OK a light bulb has gone, well I get out and check and none of my rear stop lights are working, any ideas?
    Ian
  2. quattrojames
    14,062
    583
    I expect it is the brake light switch, they are a known weak point on A4's I believe.
    There is a switch replacement guide HERE which may be of use.
    Found this on Audifans:
    "With regards to the brake lights, A4's and many other VW group cars with ABS/ESP, they have a weakness in the brake light switch. It's a 4 pin switch and this sometimes wears badly, affecting the brake lights, ABS and ESP. Note - the brake lights on a B6 A4 work without the ignition. The last thing you want on a cold morning is a flat battery :-(
    It's about a fiver from GSF or about £7 from Audi. Simple 10 minute change aswell. A worthwhile investment"
  3. sse
    sse New Member
    Hi - first post :)
    I've been having a problem since december where the brakes are sometimes on overnight leaving a flat battery. Seems to be worse on a cold night - can the switch failure give these symptoms?
    However it does seem that the brakes are on not just the lights - as I can move the auto selector from Park->Drive - or does the release of that baulk depend on the switch too?
    Would be great to get this sorted as I want to keep the car if at all possible, but can't really rely on it at present.
    A4 B6 2.0 Multitronic 2003/09
    SSE
  4. aragorn
    18,604
    870
    the auto selector lockout will only be done on the switch, not the actual hydraulic pressure produced from pressing the pedal, so a stuck on switch will mean no lockout.
  5. Niknak
    Niknak Member
    867
    All sorted now it was the brake switch!
  6. quattrojames
    14,062
    583
    Nice! :respekt:
