i have an audi a4 t 2001 with electric radiator fan problem
sorin32 Oct 29, 2009
  1. sorin32
    sorin32 New Member
    i have an audi a4 t 2001 with electric radiator fan problem it starts just after i insert the key, and dush board lights come on, before starting the engine.the air is blowing out to mi as i stand in front of the car. can anybody tell me what is wrong ? thank you.
  2. sorin32
    sorin32 New Member
  3. sorin32
    sorin32 New Member
    i both this car on 25 this month but 2 days ago the batery went dead so i changed it.from that time all this radiator fan problem. Thank you
  4. aragorn
    18,380
    831
    There are two electric fans on a B5, ones for the AC and the other is for additional engine cooling.
    Which fan is running? Open the bonnet and have a look.
  5. Geeman
    Geeman Low Life
    1,318
    I only had ONE electric fan on my 1.8T... and that was for the A/C - so I deleted it when I removed the A/C and replaced the front panel with a non-A/C unit...
  6. sorin32
    sorin32 New Member
    is the one in the right side as i stand in front of the radiator,it is right behind the radiator.Thank you.
  7. aragorn
    18,380
    831
    if its on the engine side of the rad then its not the AC fan...
    Most cars have either one viscous fan on the right of the rad, or the viscous AND an electric on the right (when looking at the engine bay from the front)
    Does your car have two electric fans?
    Either way, there will be a temperature switch somewhere thats failed, and it will need replaced.
  8. sorin32
    sorin32 New Member
    i don't know. i am not sure if i can drive it to a garage without damage anything to the engine.what do you tink ? Thank you.
  9. aragorn
    18,380
    831
    What engine does your car have?
    If you look down between the engine and the radator you should be able to see two fans. One is normally attached to the engine, the other is electric.
    The fan is just a cooling aid for slow speed driving. I would imagine that it will be perfectly safe to drive the car to a garage (and anywhere else for that matter) as long as the coolant tank is full.
  10. sorin32
    sorin32 New Member
    a4 t se 1781 cc thank you
  11. aragorn
    18,380
    831
    Well afaik, 1.8T's only have one viscous coupled fan (ie attached to the engine) then another fan infront of the radiator for the aircon?
    You say the fan thats running for you is behind the radiator?
    A photo might help?
