I Fitted clarion headunit and the rear speakers don't work? help
technics100 Jul 2, 2005
  1. technics100
    technics100 Member
    848
    24
    I have just removed my concert II headunit and fitted a clarion Mp3 headunit. now that I have fitted the unit, the rear speakers don't work. I think the rear speakers are active/powered, does anyone know how to get them to work with my headunit? my headunit unit has 2 pre-outs if that helps?
    cheers
  2. AndyMac
    9,832
    45
    Either wire the rear pre-outs into the mini-ISO block using the RCA-Mini-ISO adapter, or wire up the rear speaker outs straight to the rear speakers and by-pass the useless Audi amp
    RCA adapter
  3. technics100
    technics100 Member
    848
    24
    i dont suppose you know how to wire the connector?
  4. AndyMac
    9,832
    45
    The diagram's on top of the old Concert II HU. The connections you want are RR, LR, COM & switch (remote on)
    Looks like this:
  5. technics100
    technics100 Member
    848
    24
    will this work
    I am just going to connect the switch to the other switch on the top of the connector.
  6. That looks fine
  7. technics100
    technics100 Member
    848
    24
    Good stuff, will give it a go later.
    Does the active speaker actually have an amp? or what is actually in the rear?
  8. 4 channel amp, I'm not a 100% certain without looking at the diags, but it may be better to connect all 4 line outs to the amps, rather than just the two.
    Craig
  9. AndyMac
    9,832
    45
    Bose has a 4ch amp, non Bose just a 2 ch rear amp
  10. technics100
    technics100 Member
    848
    24
    anyone know the specs for the rear amp / speakers. Yeah it just runs the rears as the front speakers work fine and run from the normal iso connector..
  11. AndyMac
    9,832
    45
    a massive 2 x 20w
