I dont get this?
andya3turbo Jun 22, 2012
  1. andya3turbo
    andya3turbo Member
    85
  2. voorhees
    voorhees Moderator Staff Member Moderator DSG
    16,132
    1,971
  3. Lemon S3
    Lemon S3 Alex
    1,390
    41
    It can tell you all kinds of things, i used it on my mates TT the other day to read the actual engine temp as his gauges are messed up.
    I just went through the list and noted which ones would/might be useful.
  4. Lemon S3
    Lemon S3 Alex
    1,390
    41
    To access it press and hold the recirculation button. Then press the manual flow control up arrow. You should see a 1c. Press the temperature up ("+") or down ("-") buttons to select a code number. Then press the recirculation button again. The value should display. Press the temperature up or down button again to display another code.
    Here's the list of what each code does:
    1. System error
    2. Actual value feeler virtually
    3. Actual value interior feeler console
    4. Actual value outside temperature - feeler wasserkasten
    5. Actual value outside temperature - feeler bumper
    6. Actual value blowing out feeler floor space
    7. Actual value blowing out feeler man Anstroemer
    8. Display check
    9. Actual digital value acknowledging potentiometer temperature flap
    10. Target digital value temperature flap
    11. Actual digital value acknowledging potentiometer A/C flap
    12. Target digital value A/C flap
    13. Actual digital value acknowledging potentiometer Fuss/Def flap
    14. Target digital value Fuss/Def flap
    15. Actual digital value acknowledging potentiometer ram air flap
    16. Target digital value ram air flap
    17. Driving speed (km/h) ( used on movie )
    18. Actual value of the blower tension (volt)
    19. Desired value of the blower tension (volt)
    20. Actual value of the compressor/on-board tension (volt)
    21. Number of low-voltage events
    (not volatilely)
    22. Switching status of the high pressure switch
    23. Number of high pressure events (volatile)
    24. Number of high pressure events (not volatile)
    25. A/D value kickdown switch
    26. A/D value hot light
    27. Engine speed
    28. Compressor number of revolutions
    29. Coding
    30. Software-Version
    31. Software index
    32. Potentiometer error counter temperature flap
    33. Potentiometer error counter A/C flap
    34. Potentiometer error counter Fuss/Def flap
    35. Potentiometer error counter ram air flap
    36. Temperature flap notice cold
    37. Temperature flap notice warm
    38. A/C flap notice closed
    39. A/C flap notice opened
    40. Fuss/Def flap notice Def
    41. Fuss/Def flap notice foot
    42. Ram air flap notice up
    43. Ram air flap notice too
    44. Operating cycle counter
    45. Interior temperature counted (Ninc) dig
    46. Outside temperature filtered (°C)
    47. Outside temperature not filtered (°C)
    48. ECOR
    49. Coolant temperature
    50. Service life in min
    51. Engine temperature °C
    52. Compressor switching off conditions
    53. Announcement more actively el. Exits:
    Compressor/circulating air valve/water valve
    54. Rule index
    55. Outside temperature °C
    56. Interior feeler virtually °C
    57. Interior feeler console °C
    58. Temperature wasserkasten °C
    59. Temperature bumper °C
    60. Blowing out feeler floor space °C
    61. Blowing out feeler man Anstroemer °C
    62. Sun intensity W/m-1
    63. Sun intensity filtered W/m-1
    64. Delta exhaust rise
    65. Delta A/C Klappenverschiebung
    66. Time constant/1.6 seconds
    67. Cold weather starting correction
    68. Maximum correcting variable for i and p-portion
    69. Actual value blowing out feeler foot (cnts)
    70. Desired value blowing out feeler foot (cnts)
    71. Deviation (Epsilon)
    72. Portion (+ heat/- cool)
