i am f###king rageing right now
chrisw_s3mk1 Mar 21, 2013
  1. chrisw_s3mk1
    chrisw_s3mk1 Member
    62
    After fitting new front discs and pads on my s3 apy today I also fitted a new rear caliper as cylinder was seized on however straight forward and easy that was I thought to myself got to the rear passengers disc to find that the last owner/ers has kindly welded the disc onto the hub axle if this makes sense so normally you would beat the disc off hay presto its off new one on job done! Not in my case at all, why would you do that I really am at my final teathers with this car I have had it 3 weeks or so and fixed
    Dmf with clutch slave etc
    New battery
    New starter motor
    New impulse sender
    New cam belt water pump
    New discs and pads
    Serviced twice
    Cleaned oil pick up pipe and sump out
    Bypassed n249
    new coil leads
    Clutch master cylinder replaced still sticking on pressure on and off !!!!
    Really annoyed still got more problems no dout
  2. MB RS3
    MB RS3 Member
    170
    Can i ask the age please of the vehicle mate?
  3. chrisw_s3mk1
    chrisw_s3mk1 Member
    62
    V reg mate 99 plate
  4. martinivw
    martinivw :)
    455
    25
    wrong section, better in 8L section :(
  5. chrisw_s3mk1
    chrisw_s3mk1 Member
    62
    sorry my bad :(
  6. AudiS3-Turbo
    AudiS3-Turbo Member
    619
    27
    Welded? Really? Not just rusted on?
  7. chris.vincent3
    chris.vincent3 Own a BMW now, HOWEVER I still own VCDS! VCDS Map User
    606
    34
    I find it hard to believe they welded the discs on :S Got any photos?
    As said, you sure its not just rusted on, whoever fitted them didnt apply copper grease.
    Is there actually welds of metal? :/
  8. chrisw_s3mk1
    chrisw_s3mk1 Member
    62
    ive got my mate to remove it with a plasma cutter at his work place very frustrateing tbh but after much sanding and hard work its sorted now
  9. chris.vincent3
    606
    34
    glad you got it sorted, tho, i am baffled.
  10. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Bizarre ...
    I think we will have more of these stories as they get pocket money cheap, its another thing maintaining them properly...
  11. voorhees
    voorhees Moderator Staff Member Moderator Team V8 Audi S5 s tronic
    16,249
    2,072
    Spot on Dave,not talking about Chris but some buyers do not realise when something goes pop you have to buy a brand new Audi part despite the vehicle being 9 years or older.
  12. AndyMac
    AndyMac Moderator Moderator
    9,832
    46
    Why would you go to the trouble of welding them on though? They're secured by the wheel bolts so they don't actually need to be held at all, the grub screw just stops them spinning around when refitting the wheel - that really is bizarre, makes you wonder what other neanderthal "mods" they've done on the car!
  13. phil miller
    phil miller Well-Known Member VCDS Map User
    1,211
    166
    id like to see pics of this, i cant get my head round why someone would do that
    can i ask why you serviced the car twice?
  14. chrisw_s3mk1
    chrisw_s3mk1 Member
    62
    Alrite Phil wish id thought too now was fuming at the time, I asked my mate why they would do such a thing he said it was missing the grub screw and only way or reason for doing it would of been that ? Well its sorted just need to bleed the new caliper as was in a blind rage yesterday, serviced it twice just to filter any old oil that would of been in their I did it also because when I was changing the crank sensor impulse sender, I looked at the oil filter after it being changed recently, the oil was black so thought id just drop it again. Thanks for comments guys, I also wonder what else im awaiting to find.
