Hydraulic lifters
Sidey Dec 6, 2012
  1. Sidey
    Sidey Active Member
    284
    153
    43
    Hi guys,
    Is there any way to inspect hydraulic lifters?
    I think I might have a sticky one and don't want to replace them all.
    Its on a AMK motor with 100 000km.
  2. Lewis583
    956
    91
    It is possible to dismantle them. It involves a couple pieces of wood and good firm hit. There are guides on the net, have a google bud.
  3. Sidey
    Sidey Active Member
    284
    153
    43
  4. Alex C
    Alex C Well-Known Member VCDS Map User Audi S3
    3,261
    357
    what symptoms have you got?
  5. Sidey
    Sidey Active Member
    284
    153
    43
    When I start the car I got the chain rattle noise from the head, so after some diagnoses I replaced the cam chain tensioner, The noise is still there.
    I have also replaced the cam position sensor and did a sump service last night, noise is still there, between 1400rpm and 2000rpm when blipping the throttle.
  6. Alex C
    3,261
    357
    ah, yeah i was going to suggest the cam chain tensioner. I had this a couple of weeks ago and suspected tappets at first but turned out to be the cam chain tensioner. Although a single tappet would have been far cheaper :(
  7. Sidey
    Sidey Active Member
    284
    153
    43
    Agreed.
    I am stumped at the moment, was hoping to find sludge or a blocked oil pick up, but alas none of that, motor is very healthy looking for 100 000km
    Oil pan inside
    oil pickup
  8. Alex C
    3,261
    357
    i think there is an official method of checking the tappets without having to take them all out - think i saw it on elsawin when i was having issues with mine. I'll see if i can find it when i get back from work if it'll be any help
  9. Sidey
    Sidey Active Member
    284
    153
    43
    That will be greatly appreciated.
    Thank you Alex.
  10. superkarl
    superkarl MAN OF STEEL
    9,428
    2,394
    100.000km isnt alot of miles.
    what can you do to tappets in taking them apart? theyre a very simple part arent they?
  11. MIGGZ
    MIGGZ nanananananananan BATMAN
    1,461
    304
    No its not its 60k miles, mine does the same every now and again I hate it, but mine is very soft you only hear it if you 30cm away from the motor
  12. Alex C
    3,261
    357
    Here's what I found from Elsawin
  13. phil miller
    phil miller Well-Known Member VCDS Map User
    1,211
    166
    Ive seen them taken apart and cleaned, but tbh the best way is to reset them, take them out wind the tappet back in a vice, tighten up back off until the tappet is spongey refit, start engine and they will rest them selfs
  14. darren t
    darren t Member
    568
    did you change the chain itself as this could be causing the rattle?
  15. Alex C
    3,261
    357
    me? mines fixed - as i said turned out to be the cam chain tensioner. The fine piece of gauze that filters the oil before entering the tensioner broke and ended up entering the oil passageways and blocking the mechanism. Replaced the tensioner and it sounds fine now. Didn't replace the chain
