Hybrid Turbo K04
jam333 Feb 5, 2012
  1. jam333
    jam333 New Member
    hi what else is realy needed to get the best out of the hybrid turbo. i hear that a xs power manifold and 3 inch down pipe but what else should be done sud i be thinking about an intercooler. turbo timer?
  2. StaceyS3
    StaceyS3 Well-Known Member
    2,505
    502
    Intercooler, 3" tip with decent filter (would recommend the badger 5 tip) and possibly WMi to get good gains out of it but would certinally recommend putting a set of forged rods in the engine ;)
    There is of coarse an endless list of mods you can do but these are a good place to start at :)
  3. 16Klappe
    16Klappe I <3 Panda's! Supporter
    5,795
    1,187
    Yes you will need an FMIC for a hybrid to run happily, you won't need a turbo timer though. If driven responsibly you shouldn't ever need a turbo timer.
    Fitting a hybrid without any internal upgrades is pushing your luck, Bill at Badger 5 is the man to talk too if you are serious about doing it.
    There are some very good threads on here with great info on fitting a hybrid, do a bit of a search. In the mean time this is a good read on SCN -
    k04 Hybrid for 210/225 owners, LCR/TT/S3 etc-330bhp achieved!! - SEAT Cupra.net - SEAT Forum
    "fail to plan, plan to fail"
  4. jam333
    jam333 New Member
    i was looking at backdraft motorsport site at there BDM K04 Hybrid Turbo. where do you buy the bader5 tip from and how much
  5. 16Klappe
    5,795
    1,187
    Badger5...badger5 - Google Search
    Personally I would ring Bill, and talk him through your application and he will talk you through what is possible, what is probable, costings and your best way to achieve it. Buying a hybrid and slapping it on is only half of the work, if you speak to a specialist like Bill you will get first class service and will be working with somebody who knows what they are doing.
    Have you considered the fact that you will need to install rods to safely achieve the stated powers of a hybrid?
    What sort of power are you looking for? Why are you looking to do this work?
  6. <tuffty/>
    21,877
    4,202
    Don't forget Bill has his own section on ASN now...
    Badger 5
  7. <tuffty/>
    21,877
    4,202
    Hi and welcome to ASN...
    There are quite a few threads on this here, search for users Welly and Dane for a start (use the advance search system)
    Turbo timer is a pointless addition as the S3's have after run water pumps..
    Basics are..
    Decent FMIC (large ebay cooler or Welly cooler as its now know or AH Fabs V2... see the stickies for more info on FMIC's
    3" downpipe...
    Custom mapping (not stage 1/2)
    Rods...
    550cc injectors
    To get the best from it...
    Large port head (AEB/AGU etc)
    Water Methanol Injection (WMI)
    XS Power manifold
    Badger 5 80mm TIP
    Jetex filter (and heatshield if you prefer)
    Bill @ Badger 5 has done a fair few of these now...
  8. Jimgrim77
    Jimgrim77 Member
    957
    21
    Like everyone says above...Mani, rods, tip, fmic, downpipe all necessary.
    My hybrid goes on tomorrow with xs power mani. Should be interesting.
    Good luck with your build.
  9. Welly
    Welly VX220 SC Driver :)
    10,696
    130
  10. jam333
    jam333 New Member
    that fmic that you have show on ebay will need pipes and fittings where abouts do i get them from do you know any kits that will go with that item welly. basicly i have got my engine out and it seems a shame not to basicaly do what iv always wanted to du make it a flying machine im not in a massive rush to get it back tagether and im looking at the options
  11. <tuffty/>
    21,877
    4,202
    Loads of FMIC info in the stickies.... lets keep this thread on topic...
  12. jam333
    jam333 New Member
    what rods sre needed and where is the best place to purchase these
  13. Welly
    10,696
    130
    Most people use Integrated Engineering rods, but there are a fair few on the market these days, Scat and Brute amongst others make rods for the 1.8 20v T.
    I'd go with the IE ones as that's what I have fitted. Advisable following others experiences to fit rifle drilled versions.
  14. <tuffty/>
    21,877
    4,202
    Bill @ Bagder 5 sells them... Badger 5 on ASN
    Normally keeps Brute or Integrated Engineering rods... S3 will need 20mm rods (reference to the gudgeon pin size)
  15. jam333
    jam333 New Member
  16. <tuffty/>
    21,877
    4,202
    Yarp...
  17. badger5
    9,600
    2,060
    S3 have 144x20 rods..
    in stock with me in either rifle drilled or non-rifle drilled.
    £289 non, £389 with
    +vat & delivery
  18. jam333
    jam333 New Member
    sent you a email badger to your work email. what is the diffence between the too and what du du get with the extra 100 quid
  19. liquids3
    liquids3 Member
    931
    22
    And what power bhp would you recomend rods??
  20. Jimgrim77
    Jimgrim77 Member
    957
    21
    To be honest, Bhp is too narrow a focus as there is far more at play like psi and torque to consider.
    It also depends on how aggressive the mapping is but the rods can go at any time and quite low bhp figures.
    I will be continuing to limit and manage at under 300lb of torque until the rods are done.
    Any more and I'll be putting it under too much duress I imagine.
    Reliable and consistent performance delivery is my aim though.
  21. <tuffty/>
    21,877
    4,202
    Its not hp that bends them... its torque... this has been discussed more times than I care to remember tbh mate and all it ever does is create a bun fight...
    K03/4/hybrids are spikey in boost deliver... combination of that and more timing advance creates extremely high cylinder pressures that puts a lot of stress on the rods... our cars are old (regardless of mileage) and the stress of this level of tuning requires rods IMO...
    Please have a search for the other threads but if this one turns into another 'rods' thread I'll just delete them... lets keep it on topic
  22. <tuffty/>
    21,877
    4,202
    Rifle drilling provides an oil way like the OEM rods to feed oil to the small end bushes... these tend to provide better reliability under certain circumstances... non rifle drilled rely on the oil squirters
  23. liquids3
    liquids3 Member
    931
    22
    Thanks!,i will be in contact as wel then,another thing out the way then and not a bad price really!,thanks for replys,some of us are more new to more engine work mods!,thanks!,will book in for remap at some point as wel!(with front bumper of)!
  24. <tuffty/>
    21,877
    4,202
    No probs mate... the 'rod' debate always seems to bring the worst out of people lol...
  25. 16Klappe
    5,795
    1,187
    Have you seen the log of Prawns hybrid, on day one of it's tune?
  26. <tuffty/>
    21,877
    4,202
    Yes :)
  27. Prawn
    11,667
    3,669
    All I can say is that you REALLY need an XS power/relentless manifold on there with a hybrid, the gains to be had are simply insane.
  28. jam333
    jam333 New Member
    what is the differance with the stage 1 2 3 hybrid turbos except the power too the one that backdraft motorsport offer
  29. <tuffty/>
    21,877
    4,202
    The only one worth getting is one built with the 2283 comp wheel...
    CR Turbos I know do these as Bill @ Badger 5 has done a few and has defined his own spec for the ones he fits... in Wellys S3 with all the usual mods it made between 330hp and 340hp
    All this stage nonsense is just that... nonsense IMO... having been involved in most of the builds on this section of the forum where hybrids have been used I can say just buy one with that comp wheel and be done... there are all sorts of power claims with these but the 2283 is proven... have loads of data for it... its even been used in a K03 and made over 320hp...
  30. Jimgrim77
    Jimgrim77 Member
    957
    21
    Great post!
  31. liquids3
    liquids3 Member
    931
    22
    Im getting a 2280 comp (hybrid) made,because the 2283 is rarely avalible i think!,is this a bad idea?
  32. beachbuggy
    beachbuggy Well-Known Member
    1,931
    202
    Tuffty,
    The 2283 is a great wheel, beautifully made and can flow immense amount of air. I've shown this to my machine guy and he was stunned by the complexity and work involved to make this wheel and for the price it's amazing.
    All this said it is still over kill for the humble k04. Problems with surge and small exhaust housings make it a little to powerful. Yes 344bhp can be achieved but this was a one off, a practical 310-320bhp in my opinion is about right for this turbo, others may disagree. With this in mind the 2280 compressor is more than capable of this, however nobody wants a lower spec hybrid turbo, why spend £800 on a hybrid when for £900 you can have the top spec one! I agree with this but also think the some companies down play the 2280 when fitting to stage 1 turbos to warrant the extra cost of the 2283 compressor when actually it costs £18 more to buy! Call me cynical but I've learnt a lot about the business of hybrids I would be very interested in seeing what similar spec hybrids, 1 with a 2280 and the other a 2283 do side by side.
    I agree staging turbos is just a marketing tool. Fact is it pretty much costs the same to build a stage 1 than a stage 4!
  33. jam333
    jam333 New Member
    where is the cheapest place to buy a hybrid turbo
  34. Chlippo
    Chlippo Member
    679
    15
    100% agree with you on this one!
    So while getting an hybrid...get the best of it or keep it stock
  35. liquids3
    liquids3 Member
    931
    22
    by the way im not slating what you have said to me,im on a learning curve!,you and tufty have the knowledge,im asking,just want the best power for money,and you have given me a great price!
  36. Jimgrim77
    Jimgrim77 Member
    957
    21
    I can understand why but I really don't think that it's about which is cheapest but, like stated by the key men on this site, components are the key.
  37. badger5
    9,600
    2,060
    OE rods are rifle drilled.. cheaper firged are not and rely on splash lubrication to lubricate the small ends.. This in my experience is not 100%, as some installs have a faint small end rattle over time as the small end pin wears due to inadequate lubrication.
    Rifle Drilled forged rods have pressure fed oil to the small end like OE... which to me is my favoured rod. It costs more to get this done hence price is more.
    There is NO MAGIC SAFE POWER/TORQUE FIGURE where you can be guaranteed rods will be ok...
    these engines/cars are 10 years old and have done 1000's of cycles...
    It is FOOLISH to think that sub x bhp and y torque its "ok"
    Dream on... and hope luck is on your side.. cos thats what you are riding.
  38. sambryant
    sambryant stage 2+ mk2 seat leon cupra
    167
    12
    when buying rod please go for the rifle drilled. i made the mistake of buying non rifle drilled and had a nightmare trying to get them drilled. bills prices for rifle drilled rods are very good indeed :)
  39. Jimgrim77
    Jimgrim77 Member
    957
    21
    What is the price for Rods and fitment?
    They will be next.
  40. badger5
    9,600
    2,060
    rod price will depend on what type you wanted....
    fitting you are into ~£450+vat region plus parts as a guide price
