  1. bigblokey0
    bigblokey0 Member
    745
    my audi a6 1.8 t is hunting in idle when first turned on any ideas it does settle down after a while but still it shouldnt be doing it :shrug:
  2. mach1tl
    mach1tl New Member
    13
    Remove and clean the throttle body as it will be badly coked. Alos if fitted check the vacuum pipes to the secondary air valve as it can split.
  3. Verne
    Verne New Member
    22
    New to the world of Audi, but had similar problem on my Honda that was caused by a dodgy intake temperature sensor (I'm assuming Audis have them too :think:). Cleaning didn't work, but replacing with a good one solved completely
    HTH
  4. bigblokey0
    bigblokey0 Member
    745
    intake temp sensor has been mentioned b4 but ive not a clue where its located
  5. mach1tl
    mach1tl New Member
    13
    Its built into the air mass meter but do the other checks I suggested and it should be better.
