"hunting" revs? Sometimes engine revs up and down a couple hundred rpm.
grue Mar 19, 2013
  1. grue
    grue New Member
    25
    AKL 1.6, just bought it last week (103,000km) and I'm ironing out the issues with it one by one. This one has me a bit confused.
    It won't always do it, but sometimes I'll be idling and notice the revs are oscillating between 900ish and 1100ish, or thereabouts. Never acts like it'll stall, just acts like I'm blipping the throttle every half second or so.
    Timing belt is very due for a change, but I can't imagine it's related to that?
    I did just replace the coolant temp sensor, which revealed the thermostat is boned as well, could it be tied into that somehow? Otherwise, MAF, vacuum, throttle body, spark?
    EDIT:
    Some googling around makes it sound like I'd be very well served to take off my throttle body and give it some love with carb cleaner, I'll do that this weekend. Maybe tomorrow after work if I can get a gasket. That having been said, still open to suggestions on what else to check.
  2. Buzzer
    Buzzer Member
    410
    14
    As you mentioned, throttle body or you might have a leak in the pipe work.
  3. TwinCamMan
    TwinCamMan Member
    84
    I had a car that used to do that too, but only when my coolant level was low. Fixed the coolant leak and it never happened again. So I reckon you could be right on the coolant temperature sensor / thermostat area.
  4. grue
    grue New Member
    25
    What's the best way to test for the latter situation? Throttle body gasket "should" arrive tomorrow so I can do it tomorrow evening, might as well be ready to take the next step in testing after that.
    Also I'm kinda feeling foolish, but didn't realise until I refuelled last night that my car is supposed to use premium fuel, not the cheap stuff like my 8v Bora used. Presumably this is part of why my fuel economy was so bad on the first tank, hopefully fixing this issue gets it further up because I only averaged about 20mpg :(
  5. Danno57
    Danno57 Member VCDS Map User
    44
    Had the exact same issue a while back, replaced the throttle body, replaced thermostat and checked pipes for leaks, the problem still persisted so I asked a garage and they said the throttle body needs re-adapting (alignment) with vagcom, so I purchased it and done the process on the Ross tech site; my car never hunted again!
    Forgot to mention: I've got the same engine code also.
  6. grue
    grue New Member
    25
    Oh awesome. I'm gonna be cleaning the throttle body tonight just for good measure, btu I'll take it to someone with a vagcom to have 'em do that :)
  7. grue
    grue New Member
    25
    Welp, throttle body is cleaned, but I found a bit of oil in the intake hose. When I was trying to get a better look, this happened:
    Gaffer taped it back in place as a "wishful" attempt to patch it, and the problem is worse than before (less time between revs)
    It stands to reason that this was leaking and causing the issue in the first place, no? Then when I was in there dicking around, I broke it off completely and now it's worse?
    Still going in for the throttle body alignment in an hour or so, but not holding my breath now.
  8. Danno57
    44
    I guess the only way to be sure would be to have the garage do a smoke leak detection test or replace that with a new one. Let us know if the throttle alignment fixes it though, fingers crossed.
  9. TwinCamMan
    TwinCamMan Member
    84
    Looks like you'll have to go for the replacement anyway, personally would replace it before realigning it.
  10. grue
    grue New Member
    25
    alignment didn't do much to speak of, picking up a replacement pipe later today, hopefully.
  11. Dave TK
    Dave TK New Member
    22
    i got the same problem here as well ...
    I had already change PCV Valve , Breathing valve , Brand New throttle Body ... Reset and aligment done
    Still plays Up .... but as Grue said , it wont plays up everytime I drive the car ...
    Oh Mighty Audi-Sport Net , please help us .
    here the link in you tube for reference
