Hubcentric spacers?
Foxmeister Aug 6, 2012
  1. Foxmeister
    Foxmeister Fired Up!
    1,785
    Is it possible to get hubcentric type in 5mm variant?
    If so, any links please? So far i can only find from 10mm upwards.
    Cheers.
  2. olds_kool
    olds_kool Active Member VCDS Map User
    1,089
    13
    you can get hubcentric ones that centre on the hub that make fitting easier but not ones that provide a lip
    i ran them on my old car without any issues, but you should fit longer bolts
  3. Foxmeister
    1,785
    Cheers olds_kool
    What size do the bolts need to be then? Any idea where you got your spacers from?
  4. michaelg1001
    michaelg1001 Active Member
    205
    30
    I had this issue a few weeks ago, my new wheels are ET42 and wouldn't clear my brakes, so I was aiming for 5mm spacers which would just clear them. Asked some questions and people said stay away from flat spacers basically. Thinnest hubcentric ones I could find were 8mm from H&R, which I ended up getting Once I had the wheels on I realised I probably could have got away with 10mm anyway!
  5. Foxmeister
    1,785
    Really? I currently have ET35 RS4 reps and the front are near on the wing lips as it is, dunno if they might be mismatched thou?
    My new wheels are ET42 also, so was thinking 5mm spacer to get them to ET37 which would clear everything. What wheels have you got, and any pics of them fitted with the spacers to show arch clearance? Is the car lowered at all?
    Also, where did you get your spacers?
    Cheers, Mick.
  6. aragorn
    18,039
    726
    the problem with a hubcentric spacer, is that because it provides the lip for the wheel to sit on, it needs to be thicker than the original spigot on the hub.
    That spigot is around 10mm on a standard car, so hubcentric spacers arent really available below 10mm. Not sure how H&R have managed to produce an 8mm one.
    The issue with using a 5mm spacer that doesnt provide the new spigot, even if its a tight fit on the hub, is that it'll often mean the wheel simply wont locate on the centre bore at all. The centre bore on the wheel rim is usually tapered, and moving it out 5mm often moves it off the parallel section and onto the tapered bit.
    If the 8mm H&R ones really do exist, and will clear the standard spigot, then those are probably your best option.
  7. DPM
    DPM Site Sponsor Site Sponsor
    4,969
    196
    As mentioned if you want the lip then H&R are available in 8mm and above.
    Let me know if you need any prices.
    Damian @ DPM Performance
  8. aragorn
    18,039
    726
    Damian: have you got a photo of the 8mm H&R? be interested to see how they've managed an 8mm spacer when the hub spigot is usually at least 10mm...
  9. michaelg1001
    205
    30
    I don't have any close up pics, but heres mine, B5 S4 Avant on B7 DTM alloys and 8mm H&R spacers. Lowered on coilovers, taking a stab in the dark saying lowered by about 50mm.
    I got mine through Virdee Autos on AudiSRS
    My old wheels were 19s 8J ET35 with 235 width tyres so were a bit closer to the arch, gone down to 18s 8J (effective) ET34 with 225s and they fit so much better
  10. Foxmeister
    1,785
    Nice looking S, always thought the DTM rims would look good on a B5!
    Ive just checked and this particular set of wheels are 8j also, so going with the 8mm H&R's should work with these also, good to hear.
    Do you mind telling me a price you got them for, PM if you want?
  11. michaelg1001
    205
    30
    PM'd :thumbsup:
  12. DPM
    4,969
    196
  13. Foxmeister
    1,785
  14. aragorn
    18,039
    726
    no lip on those.
  15. DPM
    4,969
    196
  16. Foxmeister
    1,785
    Ok, cool.
    Im not home till Sept so im gonna wait to try a wheel and actually measure the distance as some people are fitting up to 20mm spacers and still clearing apparently, then i'll give you a shout Damien, cheers.
