HU getting power when I open the door
Anito Jan 8, 2006
  1. Anito
    Anito Member
    434
    Guys,
    I have a lovly new B7 S4 with Sat Nav (Pics will follow). I've noticed that if I either open the boot, one of the doors or unlock the car the HU is spinning up the satnav DVD. After a few seconds it goes back to sleep.
    No key in the ignition and th HU itself is off.
    Is this correct?
  2. I think that is quite normal, when you open the door, the car is getting ready for you.
  3. Anito
    Anito Member
    434
    You think?
    I don't understand why this would be, afterall when I put the key in everything is up and functioning in less than a second anyway.
    To me it's a needless drain on the battery.
  4. When you unlock your car, it comes alive and the canbus sends a signal from the central convenience to the nav unit, it then wakes up and gets ready for action.
    I would guess it also starts the GPS antenna so a fix is more readily available before you start the engine too.
    Another waste of the battery?
    Not really as the drain is minimal on a car battery.
  5. Anito
    Anito Member
    434
    ok, so it's by design then.. Thanks.
