how wide are you wheels and offset???
s3_kev Mar 30, 2010
  1. s3_kev
    s3_kev Stage2'd!!!!!!
    2,002
    23
    im currently looking at getting new wheels troble is i need adapters and the wheels are 9inch wide,
    new wheels will be after adapters et21 and 9inch wide i work this out to be 16.5mm wider then my current et25 8inch wide wheels i think there will be enough clearance as my current setup is in need of about 5mm extra.
    also the tyres will be streched as there 225's on the 9 inch wheel.
    the rears will be et21 and 9 inch wide i work this out to be 1.5mm wider then my current setup of et10 8inch wide which is near on the same so they should be fine if my workings are correct,
    i also have coilovers so could wind it up if needed but ideal dont want to so im trying to get an idea before buying the wheels as there £1500 :sadlike:
    what size wheels are you running with what offset and spacers?????
    cheers peeps
  2. jojo
    28,899
    3,553
    8.5" wide required ET30 to be safe, so I would say 9" and ET21 is pretty close, but should be enough to clear suspension.
  3. gareth_oau
    gareth_oau Member
    228
