  1. simon.m
    simon.m Active Member
    2,747
    so as above i need to clean the wiers the run from the drivers door to the post but can seem to un plug the block any one no how to do it
    thanks
    simon
  2. mlody
    mlody Member
    184
    Once you have the rubber piece off, there is a pink clip on the top of the connector, if it's on the drivers side then pull the clip towards you (towards the back of the car). That will take the plug out but it won't disconnect it. to Disconnect it, stick your finger behind the connector and look for a little 'button'. You'd be able to see it in the back door so you get the idea. It's located about half way down the plug
  3. simon.m
    2,747
    thanks mate i see the pink part but looks like some one has been there before me and looks like its snaped its the part that goes to the post id like to unplug just so i can spray it with some cleaner
  4. simon.m
    2,747
    ok done so as mlody says there is a pink clip part that you click towards you but there is also a pinch kind of part on the back side of the block going into the piller part then the block just pulls out i did this as my drivers door has not been locking on and off and the window would not open or would open then not close and i no that the wiers can brake mine are ok any how the pins where a nice greeny coulor bit of clear and all seems well ;-)
  5. quattrojames
    14,062
    583
    Sounds like you need to do us a photoguide Simon ;)
  6. simon.m
    2,747
    nope was more just as i no a few on here have that prob and most have said its the wiers broke and was just saying not always the way ;-)
