How to use measuring block 032?
abdus
Top Gear
On an Island
I've bene trying to check my O2 sensor using measuring block 032, but it keeps showing N/A.
I've been reading on VWVortex regarding initaitaing the test (don't know if it is significant here) on different engines.
Do I need to do this? My engine is an AGU engine.
Any help appreciated.
Hi Abdus how did you get on with this?
Ive logged block 32 and am getting constant values. :think:
-3.8% constantly on the ' Bank 1, sensor 1, partial load (fuel trim at elevated engine speeds (Multiplicative),' block
Maybe its just Knackered?
Anyone else had a problem with their o2 sensor ?
Cheers,
Chris
sorry i mean:
-3.1% constantly on Bank 1, sensor 1, idle (Oxygen sensors learning values fuel trim at idle (Additive), )
and
-3.8% constantly on
Cheers,
Chris
this is what I used for the AGU (it doesn't have measuring block 032 for the AGU):
http://www.ross-tech.com/vag-com/download/label-files/06A-906-018-CG.lbl
hope this helps....I've highlighted the blocks I needed to check the lambda. and the value range it should fall into. I'm still new with vagcom and learning. Someone more knowledgeable could also help ;)
BTW, i needed to check the O2 sensor for my MOT because I was getting totally wrong values on the emission test...It was all sorted in the end...(MAF wasn't connected...hehe)
But this helped to check the O2 sesnor :)
; VAG-COM Measuring Block AGU Engine Label file.
; Component number 06A 906 018 CG
; Does not work with 06A 906 018 FA (2000 US 2.0L)
; Created by James Billings. Thanks to "Dave" the VW tech who
; got me the codes!
; Visit http://ds.dial.pipex.com/town/terrace/pp70/golf
1,0,Basic Functions - Spec figures at Idle
1,1,Idle speed,800-920 rpm
1,2,Engine load,0.5-1.5 m/s
1,3,Throttle ang,0-5 deg.
1,4,Ignition ang,6-12 BTDC
2,0,Basic Functions - Spec figures at Idle
2,1,Idle speed,800-920 rpm
2,2,Engine load,0.5-1.5 m/s
2,3,Inj. period,1.00-3.00 m/s
2,4,Air mass in,1.8-4 g/s
3,0,Basic Functions - - Spec figures at Idle
3,1,Idle speed,800-920 rpm
3,2,Supply volts,10-14.5V
3,3,Coolant temp,80-105 d/C
3,4,Intake temp,-45-108.5 d/C
4,0,Idle Stabilisation - Spec figures at Idle
4,1,Throttle ang.,0-5 deg.
4,2,Idle mass,-1.7-1.7 A/T
4,3,Idle mass,0 if man/t
4,4,Op. mode,
5,0,Idle Stabilisation - Spec figures at Idle
5,1,Idle speed,800-920 rpm
5,2,Spec. idle,860 rpm
5,3,Idle reg,-10-10%
5,4,Air mass in,1.8-4 g/s
6,0,Idle Stabilisation - Spec figures at Idle
6,1,Idle speed,800-920 rpm
6,2,Idle reg,-10-10%
6,3,Lambda reg,-10-10%
6,4,Ign angle,6-12 BTDC
7,0,Lambda learned values
7,1,Lambda reg,-10-10%
7,2,Probe volts,0-1V
7,3,Valve duty,angle 0-99%
7,4,Correction,0.3-1.25
8,0,Lambda learned values
8,1,Inj. period,1-3 m/s
8,2,Idle learned,-10-10%
8,3,Learned,-8-8%
8,4,Vent mode
9,0,Lambda learned values
9,1,Idle speed,800-920 rpm
9,2,Lambda reg,-10-10%
9,3,Probe volts,0-1V
9,4,Idle learned,-10-10%
10,0,Fuel tank breather
10,1,Valve duty,angle 0-99%
10,2,Correction,0.3-1.25
10,3,Filter state,-3-32
10,4,Purge rate,0-0.3
11,0,Fuel Consumption
11,1,Idle speed,800-920 rpm
11,2,Engine load,0.5-1.5 m/s
11,3,Road speed,km/h
11,4,Consumption,l/h
12,0,Fuel Consumption [Not verified in manual]
12,1,Engine rpm,0-6800 rpm
12,2,Voltage,V
12,3,Consumption,l/h
12,4,Ign degrees,deg
13,0,Knock regulation [Not verified in manual]
14,0,Knock control
14,1,Engine speed,0-6800 rpm
14,2,Engine load,0-10 m/s
14,3,Cyl 1 ******,0-9 degCA
14,4,Cyl 2 ******,0-9 degCA
15,0,Knock control
15,1,Engine speed,0-6800 rpm
15,2,Engine load,0-10 m/s
15,3,Cyl 3 ******,0-9 degCA
15,4,Cyl 4 ******,0-9 degCA
16,0,Knock control
16,1,Sens 1 volts,0.4-1.4V
16,2,Sens 2 volts,0.4-1.4V
16,3,Sens 3 volts,0.4-1.4V
16,4,Sens 4 volts,0.4-1.4V
17,0,[Not listed in manual - Using default labels]
18,0,Altitude adaptation
18,1,Idle speed,800-920 rpm
18,2,Engine load,0.5-1.5 m/s
18,3,Throttle,valve angle
18,4,Alt. correc.,-50-10%
19,0,Additional signals
19,1,Engine speed,0-6800 rpm
19,2,Engine load,0-10 m/s
19,3,Additional,signals
19,4,Ign. timing,20Atdc-42Btdc
20,0,Operating Modes
20,1,Idle speed,800-920 rpm
20,2,Auto trans,Neutral/ON
20,3,Air cond.,AC High/Low
20,4,A/C Comp.,Compr ON/OFF
21,0,Lambda Control
21,1,Idle speed,800-920 rpm
21,2,Engine load,0.5-1.5 m/s
21,3,Coolant temp,-40-125 deg/C
21,4,Lambda mode,
23,0,Throttle valve adaptation
23,1,Learning req.,100000
23,2,Min stop,72-95%
23,3,Emerg. stop,60-91%
23,4,Max stop,18-54%
24,0,Knock control
24,1,Engine speed,0-6800 rpm
24,2,Engine load,0-10 m/s
24,3,Ign timing,20Atdc-42Btdc
24,4,Sum of ret.,angle 0-36
25,0,Charge Pressure control
25,1,Spec. load,3-8 m/s
25,2,Load correc.,0-8 m/s
25,3,Actual load,0.5-8 m/s
25,4,Valve cycle,0-99%
26,0,[Not listed in manual - Using default labels]
27,0,[Not listed in manual - Using default labels]
66,0,Cruise control
66,1,Road speed,km/h
66,2,Switch pos.,xxxx
66,3,Spec. speed
66,4,CCS switch,position
95,0,Basic functions
95,1,Idle speed,800-920 rpm
95,2,Engine load,0.5-1.5 m/s
95,3,Ign timing,
95,4,Coolant temp.,80-105 degC
97,0,[Not listed in manual - Using default labels]
98,0,Throttle Valve Matching/Calibration/Adaptation
98,1,Valve voltage,0-5V
98,2,Sender voltage,0-5V
98,3,Opr. mode,
98,4,Adapt mode,RUN/OK/ERROR
99,0,Lambda regulation
99,1,Engine speed,0-6800 rpm
99,2,Coolant temp,-40-125 deg/C
99,3,Lambda reg.,-10-10%
99,4,Lambda mode
;End of File
i think you would be more interested with the values...just the measuring blocks are different on the above
14
4K
601
