How to turn off ESP
S3 D2HTY May 10, 2010
  1. S3 D2HTY
    S3 D2HTY Member
    122
    In my S3 manual it says i should have a button on the dash for the ESP to turn in on and off but i dont seem to have this?
    I have got a 2000 210bhp model?
    Martin
  2. ikbenben
    ikbenben Belgium S3 driver
    105
    If there's no button you don't have ESP ;)
  3. mk1chopper
    mk1chopper Missing the S3
    1,092
    ESP wasnt standard on the early S3 it was an option so no button = no ESP
  4. sportstractor
    sportstractor Chugger
    2,709
    35
    gutted.
  5. S3 D2HTY
    S3 D2HTY Member
    122
    :crying:
  6. sportstractor
    2,709
    35
    sell it
  7. barters3
    barters3 Member
    438
    in my opinion s3's don't need ESP. I turn mine off every time I get in the car.
  8. mattyboy199
    mattyboy199 Well-Known Member
    1,882
    i m pretty much the same, in the wet its good fun
  9. fingermouse
    fingermouse thats me
    3,974
    110
    Car drives so much better with it off anyhow so your onto a winner
  10. finesse
    finesse Active Member
    2,805
    Never driven with it off, that warning light puts me off.
    What am I missing out on?
  11. S3 Wannabe
    S3 Wannabe Member
    197
    :yes:
  12. S3 Wannabe
    S3 Wannabe Member
    197
    I find the car more responsive and less hesitant in putting the power down.
  13. sportstractor
    2,709
    35
    yeah, but for normal social driving it has to stay on
  14. finesse
    2,805
    you'd need the ESP off with a Custard Code map :p
  15. luke2702
    luke2702 Member
    446
    Not pressed that button yet (only had car 3 weeks) but think i will have to have a play...
  16. s3 Hoggy
    s3 Hoggy Whats going on???
    1,716
    155
    Do it! its great in the wet shows you how well the haldex works!
  17. nero1701
    nero1701 New Member
    Ive had mine since saturday and turned it of for the drive home from college today....different car
    am going to look at an making a cicuit with an inverted not gate (4049) and try have it switched off when i start up and on when i press the button, will update and let you know how i get on
  18. finesse
    2,805
    :ninja::ninja:
  19. fingermouse
    3,974
    110
    best way to discover how it drives better is to find a quiet roundabout and go round it quickly with esp on and you will feel the car bog down, now do the same with it off and the car feels alive and quicker.
  20. sportstractor
    2,709
    35
    yeah, it bogs down when you start losing grip, at least mine does, its a handy tool, definately wouldnt advise switching it off all the time at it might get you unstuck someday
  21. Westy
    Westy Well-Known Member
    17,440
    1,097
    I hate the ESP big time. I have to turn it off every morning due to the uneven driveway into work. Basically the driveway is so uneven I have to cut the corner to avoid scraping my bumper on the road, this in turn sends the wheel speed sensors into a spaz because one side of the car ih higher than the other. If the ESP is on my car thinks i'm in a skid and cuts the power leaving me limping up the driveway! :shrug:
  22. JD09
    JD09 I'm not modding, I'm improving VCDS Map User
    3,096
    46
    Get in car. Put seat belt on. Turn off the **** that the misses insists on having on the radio. Start car. Turn ESP off.
    Done.
  23. Mr.G
    Mr.G Well-Known Member Team Sepang Audi S3
    1,434
    228
    Vagcom might be able to turn it off permanently! Now there's a thought with the new suspension setup and re-map i've just had.
    I'll give it a go!
    G
  24. Westy
    17,440
    1,097
    I had this thought a while ago and posted it in the VCDS board but nobody knew if it was possible. I've checked through the label files and cant see anything that will allow you to do it.
    HAve a look though mate and let us know if you find anything.
  25. SamiG
    SamiG On Boost, ish.
    233
    I turned mine off the other day when it was raining. i finished work at 9pm and thought i'd have a bit of 'fun' driving home...
    Seems to me like the back likes stepping out quite a lot on corners and roundabouts!
    It worried me a bit so i turned it back on and drove home safely. lol.
    If i'm honest i'm a little bit disappointed in the Quattro system : /
    Does anyone know what ratio the Haldex puts the power into? as in 60/40 rear/front etc.
  26. Matt82
    Matt82 Active Member
    2,365
    disappointed with what?
  27. finesse
    2,805
    Part time / "on-demand" / lazy
  28. SamiG
    233
    The fact that i put my foot down and hit a corner and the rear end tried to overtake me :S
  29. Matt82
    2,365
    well bugger audi sideways, they built a car with >200bhp that requires driver input to drive quickly.
    there are safer cars out there, pensioners etc normally like micras and corsas
  30. SamiG
    233
    No need for sarcasm pal.
    The fact the Quattro 4wd system, infact most if not all 4wd systems are in place to stop this happening seems odd that you show it a bit of open throttle on a bend and it seems to want to drift the corner rather than pull you round it. I'm capable of driving it this way i'm just saying i'm a bit disappointed at the fact it doesnt seem give me the aid in cornering that i expected. Maybe i expected too much :S
  31. damo.h
    damo.h DVLA Say it's Black
    3,610
    67
    take it it's not 50/50 on demand then ??
  32. Matt82
    2,365
    sounds like you were expecting infinity grip or playstation 3. im not questioning your sexuality or driving ability, so dont get offended. maybe youd be happier with fwd?
    the system is fwd at default and can direct power to the rear wheels depending on numerous parameters, namely the wheel speed sensors (ie detecting slip)
    i cant remember what the most power it can send to the rear is, but im suprised your car went sideways. maybe there are deeper routed mechanical issues
  33. SamiG
    233
    Guess every forum has a **** head.
  34. Mr.G
    1,434
    228
    Lol now now...handbags away lads!
    As for the car stepping out and oversteering, it's easy to do this given the right conditions, i've had mine do it when it was stock and I was driving it a bit harder than usual.
    Haldex also works off throttle position, as well as wheel speed sensors, longitudinal/latitudinal sensors as far as i'm aware.
    It would be more like 60 rear 40 front under heavy acceleration.
    G
  35. Mr.G
    1,434
    228
    PS...the modified haldex unit would be more agressive at power delivery and gives a more neutral balance while driving faster.
    G
  36. JD09
    3,096
    46
    Matt's harmless when you ignore the tripe. Sometimes he has good points to make and something to add to the forum.
    Mine stepped out the first time I swtiched off the ESP. But by a tiny amount in the wet going round a muddy corner (being rebuilt so temporary tarmac with mud from the plant equipment). However, in normal driving conditions it really does make a difference.
  37. Matt82
    2,365
    tripe is very nutritious. mmmm tripe
    if more people bothered to post in the S4 section i wouldnt have to post in here at all
  38. s3 Hoggy
    1,716
    155
    I was under the impression it never sent more than 30% power to the rear? god knows then?
  39. Deanphoto
    Deanphoto fell down the stairs :(
    96
    That shouldn't happen, if as you say, you had the throttle down sending power to all four wheels (50% F/R with the haldex system). The S3 is a nose heavy car as standard and the safe handling should see it neutralise into understeer if cornering too quickly, certainly not oversteer.
    Couple of scenarios where you might expect to see what you explained:
    1. Lift off oversteer. You take your foot off the throttle at the entrance/part way around the corner, the rear will come around. This is basic physics not helped by the Haldex which doesn't operate unless you have your foot on the throttle.
    2. Your rear tyres are worn. I had this issue, replaced tyres, all sorted now. Also worth checking suspension and bushes.
    3. Slippery road surface causing oversteer. But one would expect the front to wash away into understeer way before having a sniff of oversteer.
    Your car simply shouldn't do that. I would check the main things first, tyres for wear and pressure, bushes etc. The Haldex unit will push 50% of the power to the rear axle when needed, no more than this. Next time it's wet find a large open space and drive around in a circle, slowly gathering speed. If all is well then the front should start pushing wide way before the rear.
    If you find the car is oversteering before understeering, you have an issue. And I want your car.
  40. Matt82
    2,365
    exactly. what he said is not typical behaviour (ie for it to power oversteer... its not a beemer)
