How to turn idle up??
tyson Mar 19, 2012
  1. tyson
    tyson Member
    136
    For some reason when idling the car is shaking quite a bit have noticed the idles fairly low used to sit on 800rpm now its around 650 any ideas?
  2. Alais DJA
    Alais DJA Member
    559
    50
    Possible Fuel / Air mix issue
    When did you do a fuel filter change, and injector clean up?
  3. <tuffty/>
    21,363
    3,928
    What car/engine code? idle doesn't drop out of the blue typically... later DBW ECU's will try to keep idle at the preset idle speed (770rpm iirc)... AGU cable throttle will be adjusted at the throttle body... if you are having idling issues then it could be due to a vacuum leak
  4. tyson
    tyson Member
    136
    Engine code AMK. Its intermitant. Gave it bit of a blast and seems to of sorted it out well atleast for the next 5 mins!
  5. <tuffty/>
    21,363
    3,928
    Vac leak by the sounds then... does it bounce around a bit? might also be worth doing a throttle body reset...
