How to trick Car's Computer Into Trailer Attached Mode?
MarkJ Jul 25, 2013
  1. MarkJ
    MarkJ New Member
    2008 A4 B7 Avant
    Is there a way to activate the car's computer into tow mode when using a bypass relay for lighting? The computer has been enabled for towing, but by using the bypass relay instead of the dedicated Westfalia towbar wiring harness, the car won't know when a trailer is attached. The Westfalia wiring is still in place, but the trailer will be connected to the bypass electrical connector.
    Thoughts?
  2. NHN
    29,523
    1,766
    Usually the car is coded for the towbar module & the module itself sees a connection & thus tells the car what to do, but you don't have a module afaik that's connected to the cars network.
  3. MarkJ
    MarkJ New Member
    Thanks very much for your response.
    I also have the dedicated Westfalia towbar wiring harness installed and have enabled the tow module in the computer by entering the code. Additional background on my scenario can be found here. Is there a crossover wire I could add to the Westfalia tow bar plug, or somewhere else, that activates tow mode as needed since everything else is in place and coded correctly?
    I seem to be the only person in the U.S. that has come across the issue with the Westfalia harness and/or is trying to leverage the towing capabilities of the A4 Avant via the computer (which I find hard to believe).
    Thanks!
  4. NHN
    29,523
    1,766
    Unless the relay kit has a module that interfaces with the cars network, then its isn't going to happen, as the module connects to the cars network to tell it when something is plugged in, thus disables PDC & lights up on the dash aswell.
    I also cant imagine westfalia didn't think about the pdc side of things, unless the relay kit is specifically for cars without pdc.
