How to transfer Music from iTunes to SD card for the car?
Tom75 Aug 14, 2013
  1. Tom75
    Tom75 Member
    92
    14
    Hi everybody,
    I just got a 2014 A3 1,8 TFSI with MMi radio system and wanted to ask if there is a way to use music with the MMI that is stored on a SD card. I know it works for listening random songs etc on the card but I would like to have the music sorted by albums and artists as in iTunes on a mac.
    Is there a way to transfer the music and maybe playlist from mac to the SD card that the MMi can read it and also keeps it organized by album etc to be able to browse by album and artist?
    Thanks in advance for the help.
    Regards,
    Tom
  2. hendry10
    hendry10 Member
    73
    22
    You can obviously save all your different artists into folders . I have all different albums on my 2 sd cards , you just have to choose your album
  3. Tom75
    Tom75 Member
    92
    14
    Thanks a lot for your help, this sounds like a simple solution.
    If I understand you correctly you are not at all using playlists that are generated by iTunes? So I just have to create a folder for each artist and then safe the albums in sub folders within the artist folder?
    That would be great, I will try that.
    Thanks again.
    Regards,
    tom
  4. sftdi
    sftdi Member
    49
    What works for me at the moment (I have an A1) is that each CD album (I don't have playlists) lives in its own folder e.g.
    Folder title - Oasis - Definitely Maybe - Mp3 tracks + jpeg image of the album art
    Folder title - Oasis - Whats the Story - Mp3 tracks + jpeg image of the album art
    Only downside is that you could have a very long list of folders titles...
  5. Tom75
    Tom75 Member
    92
    14
    Thanks for the feedback, such a folder system is what I am planning to do now but I thought about to have a main folder for an artist and then have the albums in sub folders which will make the list shorter and manageable.
    Why do you have jpg's of the album art in there? Can the radio system read this?
    Regards,
    Tom
  6. sftdi
    sftdi Member
    49
    Not sure if having a main folder for an artist and then sub folders / albums will work? Maybe someone else could advise?
    The jpeg images are there to provide album art on the MMI system.
  7. sammi
    sammi Active Member
    345
    45
    I use I tune my Walkman which syncs the memory card along with I tunes and u can add yr play lists as u would on an I pod
  8. Tom75
    Tom75 Member
    92
    14
    Thanks everybody for the good information, I will do some testing and see what works best.
    Regards,
    Tom
  9. Chappy
    Chappy Call me Dan! Audi A5
    471
    25
    Can you not replicate playlists from iTunes?
  10. Belfin
    Belfin Active Member
    109
    57
    I gave up with iTunes, far too much messing about with Apple replacing album art, messing with track orders (UK releases differing from imports), etc. I downloaded Mp3tag as recommended on here in a different thread and let it sort my collection out for me. I have a 3/4 full 64gb sd card and my albums are sorted in folders in order of Artist (alphabetical order), Album Title (alphabetical order) and Track Name (as per album playing order).
    Once I had sorted and saved them on my pc, I just copied and pasted to the card. Just make sure you have the right card writer/reader (sdhc, sdxc) for the card you're using - I didn't realise there were several types!
    Cheers, Paul.
    Bronquito likes this.
  11. cemerson
    cemerson Well-Known Member Team Cosmos quattro Audi A3 S-line owners group TDi DSG
    4,592
    1,182
    ^ I do pretty much this, with the exception that I put the year of release in front of the album name (eg 2001 - Terria) so that they appear in chronological order within each artist folder
    Belfin likes this.
  12. A3sportbackMark
    A3sportbackMark Active Member
    711
    230
    43
    I have done the same as Paul, athough I don't have the car yet!
    Belfin likes this.
  13. snakehips
    snakehips Well-Known Member
    735
    262
    Just curious, is there a benefit to doing all this rather than just plugging your iPod in?
  14. MouseGB
    MouseGB Member
    54
    12
    There is a benefit, on another thread it says it will play lossless format and read album art off the SD card so your getting better quality of sound
  15. snakehips
    735
    262
    Thanks, missed that thread. Yes, B&O deserves lossless!
  16. xrkt77
    xrkt77 Member
    40
    9
    I was under the impression the only way to play Apple lossless tracks was via an ipod/iphone.
  17. Wicked666
    Wicked666 Active Member
    584
    35
    I read elsewhere that the rns system only played mp3 format - does the apple lossless format work?
    I've got rid off all my cd's as whole collection is in iTunes as lossless. Works from iPod plugged in but can only fit so many songs. May have to upgrade to rns if lossless works.
    (Or is this just for the fancy 8V system? I have an 8P)
  18. Tom75
    Tom75 Member
    92
    14
    Wow, thanks for all the input guys!
    Belfin: Just another question to your workflow, if you have already sorted all your music on the card by albums in folders etc what is this Mp3tag thing actually doing. As far as I understood if you have everything organized in folders then it should already work and if you have the cover art in the folder the MMi should also read that so what is the Mp3tag actually for?
    ...... Just found out that Mp3tag is only available for PC and not for Mac.
    Regards,
    tom
  19. Belfin
    109
    57
    Hi Tom, I used the Mp3tag program to 'unify' my music collection. Current albums downloaded from iTunes already have the required info embedded, but ripped cd's don't. Tagging the files with this program ensures that all albums; whether they be latest releases or 25 year old cd's, all have the same tags updated and relevant album art/info attached. Also, some album covers already embedded into files can be too big to display on MMI, so this way solves that too.
    I like Cemerson's idea of including the album year, so I may update my files the same way later!
    Cheers, Paul
  20. Tom75
    Tom75 Member
    92
    14
    Ok, then its clear thanks.
    Regards,
    Tom
  21. Daveotto
    Daveotto Moderator Staff Member Moderator Team Floret Silver Gold Supporter Audi S3 S3 Saloon
    3,053
    4,481
    Paul, this might be a dumb question but does this mean that on your SD card you have two versions of each track one filed under artist and the other filed under album name, so in effect you can scroll through the folders on the MMI by either artist or album to locate tracks
  22. Belfin
    109
    57
    If the army has taught me anything, it's that the only dumb question is one that's never asked!
    I only have one of each track on my SD card. Firstly, in the media folder all the artists names are listed in folders alphabetically. Inside each artist's folder the albums are listed in their own individual folders (chronologically, alphabetically, whatever you prefer). If any album has more than one CD, these are in there own folders again. Finally, inside these album folders the tracks are listed as per correct track listing.
    I hope this helps (I confused myself while typing!)
    cheers, Paul.
    Bronquito, Daveotto and Tom75 like this.
  23. Daveotto
    3,053
    4,481
    Paul, thanks for the clarification, thats how I am setting up my SD card so that hopefully I can just plug it in on day one and have full aceess to all my tunes as i drive it home form the dealer.
    Belfin likes this.
  24. cemerson
    4,592
    1,182
    Yep, i've now laid out, prepared, copied, organised, renamed and fully tagged my SD card ready for putting straight into the car when I get it!
    Belfin likes this.
  25. RossR
    RossR Active Member
    501
    122
    43
    I know this was discussed a while back, but did anyone figure out a reliable way to get album art working (on the tech pack)?
  26. Belfin
    109
    57
    I don't have the tech pack, and album artwork works fine with the way I described above. I reckon it'll be the same with yours - maybe just higher resolution pics.
    RossR likes this.
  27. RossR
    RossR Active Member
    501
    122
    43
    So that's embedded in each file using mp3tag? I'll give that a go and keep my fingers crossed it just works on the 1st. Cheers.
  28. Belfin
    109
    57
    Yep, you get to choose which cover to use too (in the case of imports, re-releases, etc). Non-tech pack artwork is restricted to 500 x 500, I think tech pack can be a bit larger.
  29. Wicked666
    584
    35
    Does Album Art work if I use an iPod with an RNS?
  30. cemerson
    4,592
    1,182
    I'm sure I saw 800x800 on here at one point...
    None of my MP3s have cover art at the moment - does anyone know if there is an easy service that can tag them automatically (like CDDB can for track names), or is it just a case of google image search and doing it manually?
  31. Daveotto
    3,053
    4,481
    I used the option in mp3tag which searches amazon etc and gives you a list of likely matches, still manual but narrows image search down very well and can tag multiple files from one album. Killed another couple of hours of my wait time
  32. cemerson
    4,592
    1,182
    Ah, marvellous - will give that a go then.
  33. cemerson
    4,592
    1,182
  34. cemerson
    4,592
    1,182
    Using this method I now have album art for 140+ albums within 2 hours - only another 115 to go :)
    All exactly 800x800 as well. God I hope that's the right size for tech pack...
  35. Toadoftoadhall
    Toadoftoadhall Active Member
    299
    80
    Interesting thread - any other Mac users found anything else as good as Mp3tag ?
  36. RossR
    RossR Active Member
    501
    122
    43
    Apparently it runs fine using parallels, if you've got that.
  37. mjcourtney
    mjcourtney Well-Known Member Team Mythos Audi A4 Audi Avant Owner Group S-line owners group TDi
    1,690
    528
    It's 500x500 max size for the Tech pack i'm afraid. In my experience the artwork i've used over that size hasn't displayed on the MMI. I will double check for you later and confirm just in case it was another issue causing them not to display.
  38. cemerson
    4,592
    1,182
    Cock! Shouldn't be too bad though, I'm keeping them all as folder.jpg so can just write myself a script to resize everything down to whatever I need it to be later, and MP3Tag can then just run through my entire collection and embed the folder.jpg into each file in one go. There is mention of someone's manual saying 800x800 on another thread though.
    Another thing that would be interesting to know - does it use the folder.jpg or the embedded version by default? Can it use either? If both are present, which does it use? I'll do a bit of investigation work myself when I get my car I think.
  39. mjcourtney
    1,690
    528
    Yeah I saw Vertigos post about 800x800 too, I will give it a go again tonight and let you know. I was still getting to grips with it last time so you might be in luck.
  40. cemerson
    4,592
    1,182
    Heh, cool. I'll finish off as I am then, and possibly take a backup of all the art once I have it all downloaded :p
