How to test can H and can L busses for interference?
Lukeyb Jul 23, 2014
  1. Lukeyb
    Lukeyb Active Member
    397
    53
    Can anyone tell me how I can check can H and can L busses for interference?
    Many thanks
    Luke
  2. john777w
    john777w Active Member
    647
    85
    Do you mean you want to identify which wire is Can h or l??
  3. Lukeyb
    397
    53
    I was on about like diagnostics for error checking, I went into optical bus diagnostics but it said my A3 doesn't have this, later I read that only MMI cars have the MOST system that this uses anyway though. Is this correct?
  4. Delboi
    Delboi New Member
    15
  5. Lukeyb
    397
    53
    The whole story is I asked around about a Bluetooth retrofit but it was too much ATM, I got hold of a setup, used genuine but when I try to code it in telephone 77 I get a too many communications errors to continue message, it was suggested that I do a diagnostic on can h and can l
  6. Delboi
    Delboi New Member
    15
    did you do the wiring yourself or was it plug and play?
  7. Lukeyb
    397
    53
    It has the plug n play loom
  8. Delboi
    Delboi New Member
    15
    It's not likely to be a wiring issue but more likely a defective unit, try and borrow one to test in your car
  9. Lukeyb
    397
    53
    I have arranged a replacement module so will have to wait for it to come. I had my car into Audi for something else and while I was there asked if they can check my wiring and see if they can check the module. There's nothing wrong with the cars wiring systems and they can't communicate with the module either. So it's definitely the module at fault.
  10. Lukeyb
    397
    53
    Replacement module works fine it was a duff box
