how to test a dump valve?
lol4fun Feb 7, 2014
  1. lol4fun
    lol4fun Member
    190
    I have a problem, when I put a standard recirculating valve on my car it chatters like its not opening and I've tried this with 2 but when I put a forge one one it sounds like its leaking under boost. How can I test them?
  2. VAG-Slag
    VAG-Slag Well-Known Member
    1,759
    405
    The simplest way to test is to push the piston up by poking something through the bottom, then create a seal with your thumb over the top where the vac hose would go and see if the piston returns... If it does then it's buggered
  3. Kuvi-S3
    Kuvi-S3 Active Member
    175
    49
    Same way to test that was told
  4. <tuffty/>
    21,225
    3,874
    If the Forge one (assuming its a 007 or 008 and not the crappy split-r) has an o-ring on the bottom of the piston then it shouldn't leak at all under boost... if its a metal bottomed piston then get a service kit for around 15 quid that has the new design piston in or just buy a new OE valve
  5. <tuffty/>
    21,225
    3,874
    ...and there are two threads in the FAQs about DV's and testing stuff etc... :)
    JD09 likes this.
  6. JD09
    JD09 I'm not modding, I'm improving VCDS Map User
    3,096
    46
    I just did this... Goodbye old 007P. eGay here it comes!
  7. Eddie S3
    Eddie S3 Member
    128
    9
    My two OEM ones are still both making a hooting noise :( Stuck the leaking 007 back on for now
    This was me testing my 007
  8. JD09
    3,096
    46
    Is that not leaking from the pipe? Difficult angle to tell!
  9. Eddie S3
    Eddie S3 Member
    128
    9
    It was a while ago I recorded that but it was definitely leaking out of the bottom
  10. daz-20vt
    daz-20vt Well-Known Member
    2,835
    583
    Under how much pressure was that. And how long is that pressure on the dv? Is it constant while the turbos spinning? I know nothing about how this works im sure im going to look stupid here.
  11. <tuffty/>
    21,225
    3,874
    Pressure on the DV is there while 'on boost' dude... once throttle is closed then there is vacuum on the top that lifts the valve and release the pressure back into the TIP... if air is leaking past (as per the vid) thats air thats not getting to your engine and this equals power loss
  12. daz-20vt
    2,835
    583
    Wow thats just incredible. I think im going to sell my 007 and get an oem. Sound wise?
  13. <tuffty/>
    21,225
    3,874
    Forge have revised the piston so should no longer leak... get a service kit for 15 ish quid which includes piston, o-rings and grease and treat it...
  14. lol4fun
    lol4fun Member
    190
    All 3 the piston drops as soon as I release it from pushing it up while blocking the vacuum end. I can blow through both the standard vacuum ends and hear it leaking. The forge one is a split r, I bought it before doing any research -.- lesson learnt
  15. JUS3IN
    JUS3IN 14.0 @ 98mph 2s 60ft
    1,159
    102
    make sure they are on the right way round aswell lol!-)
  16. lol4fun
    lol4fun Member
    190
    Which way around is the proper way?
    Ordered a standard DV from my local vw dealers today, only £37 including vat.
  17. <tuffty/>
    21,225
    3,874
    Don't bother testing the split-r... they just leak... period! :)
  18. JUS3IN
    1,159
    102
    as you had a split r im thinking that had the vacuum pipe horozontal, the stock dv's are vertical as tuffty taught me lol... so on the stock the vacuum pipe points at the sky.
  19. lol4fun
    lol4fun Member
    190
