How to tell if my central electrical module is a "highline"?
P77HLP Mar 26, 2014
  1. P77HLP
    P77HLP Member
    75
    Hi Guys,
    In the early stages of a heated seat retrofit, I'm told I need a new central electrics module,
    i would just like to make sure this is needed before I proceed
    Phil.
  2. hades-
    hades- Yorkshire & Humber Rep. Regional Rep VCDS Map User
    9,480
    646
    2 ways
    remove it and get part number
    or vcds for part number
  3. P77HLP
    P77HLP Member
    75
    Cheers bud, do you know what the highline part no is? Or where I can find it?
    P
  4. Adam Russell
    Adam Russell Member quattro Audi A4 S-line owners group TDi
    186
    did you ever find out what the part number is as i currently have
    8K0907063N but doesn't seem to have the pins for heated seats?
  5. Adam Russell
    186
    have you done this ?
  6. desertstorm
    desertstorm Moderator Staff Member Moderator VCDS Map User quattro Audi A4 Audi Avant Owner Group TDi
    5,162
    2,204
    If you look at the PR codes associated with a module you can usually get an idea what it does. If you find your part number on the parts listing
    8K0907063N
    http://audi.7zap.com/en/rdw/audi+a4+s4+avant+quattro/a4q/2008-636/9/907-907004/#1
    One of the PR codes associated with that module is 4A0
    Use an on line PR code decoder tool .
    http://prsearch.planetvag.com/
    PRCode: 4A0 = Without seat heater
    PRCode: 8BP = Bi-functional headlight with gas discharge lamp
    PRCode: 8EH = Bi-functional headlight with gas discharge lamp for driving on the right(US design)
    PRCode: 8X0 = Without headlight washer system
    PRCode: 8X1 = Headlight washer system
    The code for seat heating is 4A3 or 4A4
    PRCode: 4A3 = Seat heater for front seats separately controlled
    PRCode: 4A4 = Seat heater for front and rear seats separately controlled
    Depending on the combination of options you need determines which is the correct module. Nothing is simple with modern cars .
    Sandra likes this.
  7. Adam Russell
    186
    this is really helpful, does this mean theres two variants of N or is it saying N can do both ?
  8. Adam Russell
    186
    if does both then looks like ill need a P
  9. desertstorm
    5,162
    2,204
    There is only one Model N version it is just used in two specifications of car. What it really means it that the N supports cars with xenon headlights and headlight washer systems but not seat heating.
    Usually this kind of thing is documented as it is common for these modules to be upgraded when retrofitting options. The P revision looks to be the one based on the options the N has.
