How to tell if cambelt done?
Johnjones Dec 30, 2012
  1. Johnjones
    Johnjones Member
    51
    Hi, I'd like to know how to tell if the cambelt was done recently. The old owner said it was changed around 10k ago, but no proof. Can i visually tell? The fanbelt looks like it's new on the outside but the inner edge has small cracks in it or is that normal after 10k, .....Any ideas? Many thanks
  2. Mike B
    Mike B Well-Known Member
    1,101
    40
    No way to know.Dont chance it
  3. hades-
    9,481
    646
    fan belts nothing to do with it
    but as above i look at it this way
    no proof its not been done
  4. mikeyboy
    mikeyboy S-line
    431
    51
    Dont risk it just get it changed along with the waterpump. It will put your mind at rest.
  5. stu_m
    stu_m Well-Known Member VCDS Map User
    1,441
    unless its in the service manual or there is the sticker on the cam belt cover you have no way to check
    I would get it done for peace of mind
  6. demus
    demus Fire in the hole..
    355
    19
    And as above defo new water pump as well, for the price its silly not too, if the pump packs up a few miles later its all gotta come out again..
  7. Johnjones
    Johnjones Member
    51
    ok, will do...thanks for the advice! Anyone know a good reasonable garage near Bristol?
  8. 666markyboy
    666markyboy Well-Known Member
    1,211
    49
    This is the exact reason i keep my bills for parts and take photo's whilst i do the job taking some with the bill for the parts sat on the stripped down engine.... i don't even trust service books anymore as they can be bought on ebay all stamped up for you... a few dated digital photo's goes much further imo....
  9. adamss24
    adamss24 Well-Known Member
    4,584
    406
    As above, do it again for piece of mind ! Seen a few engines in my time with mangled heads due to messed up cambelt jobs or broken belts. With prices ever growing the bill will run into thousands, it's not worth-it !
  10. IF the printing on the belt looks newish then that would be good enough for me but if you have never seen a cambelt before you may not know what to look for. You will obv need to remove the belt cover. Or take a photo and post here. IF you get a blank spot, crank the engine until you can see some print on the belt..
  11. Johnjones
    Johnjones Member
    51
    Is it easy to take the cover off? Could you tell me how? Thanks
  12. marktdisport
    marktdisport Active Member
    1,195
    15
    Yeah don't bother taking the chance, that's how to remove it...... Unless you want a £1000 bill when it trashes the head and valves.... I'd never advise anyone on a forum to check it by looking at the writing on the belt......... I'm sure if your asking how to remove the belt cover then your not competent to check the life of the belt anyhows... Sorry to sound harsh but when your in the trade and seen what damage they can do you'll understand
