how to stop my s3 understeering?
edward_harris Feb 13, 2007
  1. edward_harris
    edward_harris s3 gone now a shiney red evo 6
    1,061
    anyone no anything that will stop s3's understeering, if you go into a roundabout etc it just goes straight on, my mates rover coupe handles better than my s3!
    any sloutions?!
  2. ChriS3
    ChriS3 hud at ye bam
    2,239
    27
    ARB's, the Haldex Peformance Part, good shocks and springs, good tyres, and a lot more neg camber at the front!
  3. DPM
    DPM Site Sponsor Site Sponsor
    5,040
    212
    :iagree:
  4. S3Steve
    S3Steve Active Member
    1,621
    20
  5. edward_harris
    1,061
    does this really make alot of difference then? why is it so bad standard?!
  6. Tooks
    Tooks Active Member
    753
    30
    Because in this litigous world we live in, and the average skill of your average driver, it's safer for cars to be setup to understeer.
    Tis the way of the world, just as my wife will buy new shoes given the chance, and I will look at internet porn given the opportunity!! ;)
    I've probably said too much there!!
  7. Defratos
    Defratos You’re Dethpicable!!
    2,232
    I second that, my S3 handled like a pig before the Suspensions, in particular the ARBs and tie-bars, I still need to get the haldex. Oh and bushes might help, dunno really.
    Hey Chris how do u get more neg camber on the front? I've read Glen's post but didn't really get what he meant, does anyone have a slightly simplistic explanation for the front camber?
  8. Tooks
    Tooks Active Member
    753
    30
    This help?
    Think of negative camber like spreading your legs further apart to steady yourself on a rocking boat! Or is that not what you meant? Did you mean HOW do you adjust it?
    EDIT: Won't let me link the explanation, but it's here about 3/4's of the way down the page....
    http://www.carbibles.com/tyre_bible.html
  9. buckas
    buckas Member
    749
    check your tyres are up to the job would be my first check, heh - but after that, echo what has been said above :sm4:
    drew
  10. ChriS3
    2,239
    27
    Poly bushes help everything feel better and tighter, but I'm not sure if they really helped with the handling. The haldex made a big difference (IMO) to the whole set-up of the car. Big difference, but still very subtle.
    I'm maxed out at -1.3 deg at the front. You need to make sure the sub-frame is bang in the middle, the you can push the camber out. You have to tweak ball joints and things to get to -1.5
  11. Could always put a bit more air in your back tyres to help balance things out ;)
  12. ChriS3
    2,239
    27
    Oh and tyre pressures to 34psi front, 38psi rear (if you're on 18s)
  13. simch
    simch Active Member
    2,028
    With a stock one the only way to not get understeer is not to steer it!!
    hahaha
    What everyone else says, I have billys, H and R springs and a HUGE race neuspeed rear ARb coming to get mine dialled in as i like it!!
  14. scib4
    scib4 Beep-Beep!
    272
    What should they be if your running standard 17" as i am?
  15. ChriS3
    2,239
    27
    It's beena while since I ran on 17s, but I think 32 front, 36 rear was good.
  16. DavidR
    DavidR Active Member
    1,296
    Move the engine further back...
    You'll never stop an S3 understeering - it's in the nature of the chassis and weight distribution.
    The above mods can help, but even with max negative camber with a very brave lengthening of the front suspension mounts it will still understeer. TBH the chassis on the S3 wouldn't really cope with a truly neutral setup - too much flex to catch the back of the car in extremis.
    Best plan is to drive round it. ChriS3 is (unusually) correct though. The Haldex controller makes the car alot more neutral and is highly recommended.
  17. leecs3
    leecs3 thinking about stuff
    604
    S3 isn't worth driving with uprated ARBs.
  18. Hotscar
    Hotscar Four Wheel Drifting
    562
    Use the throttle and then don't use it...
  19. fingermouse
    fingermouse thats me
    4,009
    ????? mine feels better with the R32 ARB in what way isnt it worth driving in this form ????
  20. edward_harris
    1,061
    will he tyre pressures really make a big differnece, im running 30 all round on 18s, but my old a3 1.8 i had s3 wheels on it and when ever i put the pressure up it really understeered!!
  21. leecs3
    604
    sorry, meant not worth driving without uprated ARB's. Typo.
  22. Yeah, but did you have the same pressure all round?
    I find that if I have a bit more pressure in the back tyres than the front that it helps a bit (not a massive difference but it helps) :yes:
    30 seems a bit low btw, you sure that's right ?
  23. edward_harris
    1,061
    dunno f its right thats what someone told me!!
  24. rodenal
    rodenal Active Member
    1,992
    30 is too low really, 34 front and 36-38 rear will be much better as said above
  25. fdussud
    fdussud Member
    40
    All I added to my car was a haldex performance controller. I could not believe the difference. In the wet on a round about, it use to understeer alot when I pushed the car hard but now with the performance controller, the car is neutral.
    Makes you feel alot safer driving hard in the rain and dry.
  26. Defratos
    2,232
    ohhh good thing you corrected that quickly, I was about to give you a paragraph or two for why its good lol :beerchug:
