How to stop dash lighting up when the headlights are OFF? VAGCOM?
c_w Apr 13, 2010
  1. c_w
    c_w Well-Known Member
    1,163
    87
    I've notice a curious thing with the A3, it may be a common thing with VAG cars I'm not sure; the dash (speedo etc) cluster lights up on it's own and it makes it appear that you have turned the lights on (or is it always lit up, just that in the day you can't see it?? Though I'm sure sometimes its not lit up in slightly duller conditions). It seems a strange thing to me, since why would you want the dials lit up without headlights on, as it makes you assume you have lights on!
    Our previous car had auto lights, so at dusk the lights would come on and so would the dash lights. As far as I can see the Audi doesn't have auto lights but you could be mistaken to think you had lights on because the dashboard (speedo/rev etc) is lit up even though you have no lights on! Can this be altered perhaps in VAGCOM? so that the dash never lights up unless at least side lights are switched on?
  2. smudge_don
    smudge_don Active Member
    2,944
    I prefer the dials lit up, so i often drive with my sidelights on
    I'm sure there must be something in VAGCOM to change it
  3. c_w
    1,163
    87
    But atm they are lighting up with no lights on at all!? Hopefully there's vagcom setting for it!
  4. smudge_don
    2,944
    I'd prefer that!
  5. Gti Jazz Blue
    Gti Jazz Blue Active Member VCDS Map User
    1,655
    This is a translation from the OpenODB website created by Sebastian Stange (some English info but for the Cluster Info I have had to use GoogleTranslate, to translate from German to English).
    (Instrument cluster
    Steuergerät Codierung
    Control Module Coding
    STG 17 (Kombiinstrument) auswählen
    STG 17 (instrument cluster) select
    STG Codierung -> Funktion 07
    STG coding -> Function 07
    00??xxx : Restcodierung
    00?? Xxx: residual coding
    +01 - 2-te Tankkennlinie bzw. Quattrocodierung​
    +01 - 2-th Tankkennlinie or Quattrocodierung
    +02 - Highline ohne FIS (für Midline - Automatik ohne FIS)​
    +02 - High Line without FIS (for Midline - Automatic without FIS)
    +04 - Handschalter bzw. Kupplungsfahrzeug (nicht Midline)​
    +04 - Handset or vehicle clutch (not midline)
    00xx?xx : Ländervariante
    00xx xx?: Country version
    0 - Deutschland (D)
    0 - Germany (D)
    1 - Rest der Welt (RdW - Linkslenker)
    1 - Rest of World (ROW - left handed)
    2 - USA (US)
    2 - United States (U.S.)
    3 - Kanada (CDN)
    3 - Canada (CDN)
    4 - Grossbritanien (GB - Rechtslenker)
    4 - Great Britain (GB - RHD)
    5 - Japan (JP - Linkslenker)
    5 - Japan (JP - LHD)
    6 - Arabische Staaten​
    6 - Arab States
    7 - Australien (AUS)
    7 - Australia (AUS)
    8 - Rest der Welt (RdW - Rechtslenker)
    8 - rest of world (ROW - right hand drive)
    9 - Japan (JP - Rechtslenker)
    9 - Japan (JP - RHD)
    00xxx?x : Gurtwarnung
    00xxx? X: Seat belt warning
    keine Gurtwarnung
    No Seat belt warning
    Gurtwarnung Europa-NCAP
    Seat belt warning Euro-NCAP
    Optische dauerhafte Warnung, Akustische Warnung für 91 Sekunden aktiv.
    Optical permanent warning, Audible warning for 91 seconds active.
    Gurtwarnung USA und Kanada alt
    Seat belt warning USA and Canada old
    Optische und akustische Warnung für 6 Sekunden
    Optical and acoustic warning for 6 seconds
    Gurtwarnung USA und Kanada NAR neu
    Seat belt warning USA and Canada, new NAR
    Optische dauerhafte Warnung, Akustische Warnung alle 30 Sekunden
    Optical permanent warning, Audible warning every 30 seconds
    Gurtwarnung Europa-NCAP (einschl. Beifahrer)
    Seat belt warning Euro-NCAP (incl. passenger)
    Gurtwarnung USA und Kanada alt (einschl. Beifahrer)
    Seat belt warning USA and Canada old (incl. passenger)
    Gurtwarnung USA und Kanada NAR neu (einschl. Beifahrer)
    Seat belt warning USA and Canada NAR new (incl. passenger)
    00xxxx? : Beleuchtungsoptionen
    00xxxx?: Lighting Options
    Hinweis : Die Optionen 4-9 stehen erst ab MJ 2005 zur Verfügung.
    Note: Options 4-9 are available only from MY 2005.
    Ab MJ 2005 ist bei den Optionen 0-4 ist die Kontrolleuchte für Standlicht AUS und bei den Optionen 5-9 ist die Kontrolleuchte für Standlicht EIN.
    From MY 2005 is at the options 0-4 is the parking light warning light OFF, Options 5-9, the indicator light for parking lights ON.
    0 - Zeiger und Skalen AUS (bei Kl.15 Ein und Kl.58 Aus)
    0 - pointers and scales off (at a terminal 15 and Kl.58 Off)
    1 - Zeiger EIN, Skalen AUS (bei Kl.15 Ein und Kl.58 Aus)
    1 - A pointer, scale OFF (at terminal 15 A and Kl.58 Off)
    2 - Zeiger AUS, Skalen EIN (bei Kl.15 Ein und Kl.58 Aus)
    2 - hands off, scale A (at a terminal 15 and Kl.58 Off)
    3 - Zeiger und Skalen EIN (2. Dimmkennlinie - Kl.15 Ein / Kl.58 Aus)
    3 - pointers and Scales ON (2nd dimming characteristic - terminal 15 A / Kl.58 Off)
    4 - Zeiger und Skalen EIN (ohne 2. Dimmkennlinie - Kl. 15 / Kl. 58 Aus)
    4 - A pointer and scale (2nd dimming characteristic - Cl 15 / Cl 58 from without)
    5 - Zeiger und Skalen AUS (bei Kl.15 Ein und Kl.58 Aus)
    5 - Pointers and scales off (at a terminal 15 and Kl.58 Off)
    6 - Zeiger EIN, Skalen AUS (bei Kl.15 Ein und Kl.58 Aus)
    6 - A pointer, scale OFF (at terminal 15 A and Kl.58 Off)
    7 - Zeiger AUS, Skalen EIN (bei Kl.15 Ein und Kl.58 Aus)
    7 - hands off, scale A (at a terminal 15 and Kl.58 Off)
    8 - Zeiger und Skalen EIN (2. Dimmkennlinie - Kl.15 Ein / Kl.58 Aus)
    8 - Pointers and Scales ON (2nd dimming characteristic - terminal 15 A / Kl.58 Off)
    9 - Zeiger und Skalen EIN (ohne 2. Dimmkennlinie - Kl. 15 / Kl. 58 Aus)
    9 - Pointers and Scales ON (2nd dimming characteristic - Cl 15 / Cl 58 from without)
    Steuergerät Anpassung
    Control adjustment
  6. c_w
    1,163
    87
    Thanks, looks like it could be a setting in that last block!
  7. alistairm1
    alistairm1 Active Member
    175
    107
    43
  8. Ash187
    7,489
    742
    i think i heard that there is a light sensor at the cluster so when it gets dark outside it (in a tunnel) will light up briefly so that you can see the dash. I dont have the auto rain/lights pack but i notice that the cluster lights up for a few secs when i go into a tunnel, but if i am in a long tunnel it just goes dark after a while and i only have the red dials lit up. I actually prefer the lights to come on and am now thinking of getting the auto lights/rain sensor installed.
  9. SAiLO
    SAiLO Well-Known Member VCDS Map User
    1,075
    62
    Yes there is a light sensor in the speedo, when the ambient gets a bit dark it will light up the dash lighting. The lights stay off until you see the green headlight icon lit up on the cluster.
    Hope that helps.
  10. c_w
    1,163
    87
    This makes sense as sometimes I've noticed the dash not lit up and then sometimes is, must depend on the lighting conditions. However, my car does not have auto lights so I think it's a bit of a strange setup.
  11. PH1L
    PH1L Gievf Buckets
    3,851
    40
    you can also set what you want lit via vagcom, ie if you dont want the needle lit when your sidelights are on
  12. kkp0897
    kkp0897 Active Member
    768
    45
    Apologies for the thread hijack but anyone know how to code the instrument cluster not to light up until the headlights are turned on? They are on from when the ignition is turned.
    I have auto lights and my query is related to MY2010
  13. audicruiser
    audicruiser Audi Heaven
    1,865
    Your car is coded like that from the factory but it can be changed in vcds. Not sure why you would want to though if you have Auto headlights...
  14. audicruiser
    1,865
    Its actually the other way around. When the ambient light drops the dials go dark so the driver know to turn the lights on...
  15. Ash187
    7,489
    742
    you go into the instrument cluster coding and change the last number to 3 to make it dim at night to remind you to turn on the lights
    code it to 4 to have the lights permanently on
  16. quinnii
    quinnii Active Member
    328
    94
    Iv set mine do that the needles are always lit, I like seeing the needle sweep at night with just the needles lit!
  17. kkp0897
    768
    45
    Thanks,
    Apologies if ive not made myself clear... Yes I have auto lights so when lights turn on automatically so should the instrument cluster backlight.... However in my case (and from factory) instrument cluster back light is on permanently and What i want is only the instrument cluster to turn on when lights are (automatically) turned on.
  18. audicruiser
    1,865
    Needs to be set as per Ash's post above then... Change the 4 to a 3.
  19. davc
    davc Well-Known Member Team Glacier Audi S3 quattro s tronic saloon
    635
    629
    93
    I have auto lights and it does this even when the switch is set to auto. Is this normal?
    I would've thought that if the lights were set to Auto with just the DRL's on, that when the light fades, the cluster wouldn't go dark as the dipped lights would be activated automatically?
  20. c_w
    1,163
    87
    I'm not sure but the combination of dials being lit and DRLs causes issues IMO. Just last night I'm on the motorway at 8pm and 5-series in front with no (tail) lights on. Driving alongside I can see his dash fully lit and his LED DRLs blazing at the front (so he can probably see the reflection of these on cars in front so assumes they're on).
    But as we know DRLs, especially LED ones from AUDI/MERC/BMW/CITREON/PORSCHE etc are very bright and blinding at night/dusk. Surely it should be law (much like the HID having to have levelling/washers) that cars fitted with DRLs must have auto lights that switch on normal/proper lights at dusk/dark??
