How to secure the Jetex filter?
DJ_Troopa Nov 23, 2010
  1. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    14
    Well i'm looking to buy once again another MAF soon as i've had 2 die in 4 months! Crappy GSF if you ask me! They were the Bosch units too.
    Anywho.... i know vibrations can also cause the MAF to fail and i was wondering how people have secured their filters to stop these vibrations?
    Advice and pictures are appreciated!
  2. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    I've made an heat shield for mine, doubles up as an anchor, i will get a pic up tonight
  3. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    14
    That will be great Dave :)
  4. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    14
    If anyone else has advice please let me know. I think this will be interesting for others too.
    Jay
  5. DaveA3
    DaveA3 Audi A-Trizzle!
    2,370
    15
    mine sits pretty tightly behind my battery dont really move. ill post a pic.
    but then again i have an A3 so probably irrelevent
  6. MURRAYS444
    MURRAYS444 Member
    790
    Two zip ties attached to the strut brace its cheap and a bit nasty looking but it works!!!
  7. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    14
    Scott - haha i done that with my last filter which was the Invo filter. It still wobbled quite a bit then!
  8. DaveA3
    2,370
    15
    that reminds me i have my ignition amplifier cable tied to my jetex aswell maybe that helps
  9. A3Tom
    A3Tom Smell my finger.
    3,504
    14
    I run a pipercross one on mine and it came with a bracket to fix it to the airbox mounts. I wouldnt have thought it would be too tricky to knock something up to secure it.
  10. badger5
    9,378
    1,920
    did the MAF fail dead low/no sensor signal or just read too low?
    Some have mounted via a bracket off the gbox a support mounted by those rubber bobbins to support yet isloate the maf sensor and clamp it to one of the 2 holes vacated by the screws which used to screw it to the airbox.
  11. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    14
    My MAF readings are 200 g/s :( When i had the BMC i was doing 208 g/s, then after 2 months it went to 200 g/s. I bought the Invo and still the same. Funny how i need a new maf again! Drives me mad!
    Not sure what area you're talking about to secure the filter Bill?
  12. badger5
    9,378
    1,920
    vibration kills maf's dead, it does'nt cause them to underread.
    I would look elsewhere as I fear you are chasing g/s figures and the cause lies elsewhere perhaps
    leeds_182 likes this.
  13. MURRAYS444
    MURRAYS444 Member
    790
    I also kept the bottom part that holds the original air box it doesn't move much but I should really find something more secure!!!
  14. s3dave
    10,110
    736
    Here are my pics made from aluminium, it touches the engine bonnet blanket so it is a fairly good seal, needs a little tweaking but it is solid.
    By d121m at 2010-11-23
  15. Speedy Steve
    Speedy Steve Active Member
    1,258
    Cable tie racing FTW
  16. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    14
    That's what i've been thinking aswell. I've changed the breather hoses to the Forge ones and also changed the engine block breather valve as that was clogged full of **** and broken! Is there anything else you can suggest Bill as you suggested these 2 things to me before? Would a book leak test help? That's next on my list!
    Yeah i've got the bottom part too with the standard feed. The standard feed sits in a nice position in front of the filter.
  17. badger5
    9,378
    1,920
    boost leak test will confirm any lingering losses yea. if none, then that can be eliminated
  18. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    14
    Thanks for the pics Dave, looks neat! Did you make that yourself? I need something like that :)
  19. s3dave
    10,110
    736
    Yes made it out of aluminium sheet, needs tweaking a little then i will start making them...
  20. JamJay
    JamJay Member
    188
    I have mine secured with a Neuspeed shield.
  21. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    14
    I've just spoken to Jabba who said they do their heat shield for £85.
    Bill - you have a Jabba one on your car don't you?
  22. badger5
    9,378
    1,920
    LOL - no I dont have anything Jabba on my car for many years now
  23. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    14
    Oh, i thought you had the heat shield though?
  24. badger5
    9,378
    1,920
    nope. gone many years ago
  25. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    14
    You don't have it lying around anywhere by any chance do you? lol ;)
    I'm not sure if i want to spend £85 on it from Jabba, do people think it's worth it? Pricey if you ask me!
  26. badger5
    9,378
    1,920
    nope not here
  27. m8arx
    m8arx Member
    170
    how easy is it to make up a heatshield for these? is there any particular thickness of aluminium to use? what size is the hole that the maf sits in???
  28. jay1601
    jay1601 Well-Known Member
    1,310
    57
    s3Dave what thinkness aluminium did you use ?
