how to request swap transponder in 3 button remote
Fraser Jun 25, 2008
  1. Fraser
    Fraser Member
    584
    My 3 button remote key has a snapped key blade, so I want to:
    1. swap the top end with a new blank flip and blade section
    2. swap the transponder to the new front section
    I can separate the key ok but can't for the life of me work out how to open the front section of the key (that includes the flip blade) so I can access the transponder to swap it to the new one
    tia
  2. NHN
    29,332
    1,716
    They are sealed in the top part with glue, the actual transponder is also glued into place & as its a glass capsule you have to be so bloody careful you dont break when taking the glue of, you would need a dremel to take it out that carefully, trust me its not easy, I did 1 then 2nd one broke, typical huh.
    On the rear there is an Audi chrome small badge, under that there is a screw that allows you to seperate the top but, but as above, it might also be glued so be careful.
  3. Fraser
    Fraser Member
    584
    i figured the screw under the logo from another site, could prise the halves apart a touch but it is firmly glued. Looking at it now I only need to swap the full key blade. I will have another go when I am feeling braver!
    thanks for the reply
  4. NHN
    29,332
    1,716
    I did wonder why you didnt just swap the blade TBH but glad you resolved now.
