How to remove the hose clamp in order to fit a CAI on an S3?
prt57 Oct 21, 2013
  1. prt57
    prt57 Well-Known Member
    884
    278
    Hi,
    I have been thinking about fitting a CAI to my S3 8P but at the moment I am wondering how do you undo the nasty hose clamp where the plastic tube from the original air filter goes down the back of the engine to the RHS of the master cylinder?
    There is not a lot of access and so the conventional plumbers pipe grips or squeezy clamps have no room to get a grip.
    Would I be correct in thinking that these would do the job?
    BGS - Flexi Ratchet Hose Clamp Pliers For Fuel & Coolant Hose Clips 630mm Bowden | eBay
    Also if this is the correct tool, do you attack this clip from the top or up from underneath?
    What is the current thinking of CAI quality and fitment? I am only interested in a super quality item where appearance is excellent and there are no issues in the fitting.
    Thank you,
    Peter
  2. Staz
    Staz is a retronaut Moderator VCDS Map User
    6,206
    67
    Having just removed my Evoms CAI I have a lot of sympathy for you. That bottom clip is a right pain to get to but you really have to persevere and eventually you'll get it off.
    Hopefully your replacement CAI will come complete with jubilee clips which makes the fitting job a cinch in comparison. If not you need to buy a 70-90mm jubilee clip. Don't even bother trying to refit the original clip, I gave up after 45 minutes. My hands don't have the dexterity they used to have!
  3. prt57
    884
    278
    Thanks for the reply, but what did you use to get the clip off?
    Regards,
    Peter
  4. Staz
    6,206
    67
    I did mine a few years ago so I have no idea, probably just adjustable pliers. I remember it being a pain but not that bad.
  5. bmh.01
    bmh.01 Member
    291
    17
    A remote tool as you've linked makes it easy, so do long nosed pliers. Done several never had a problem using either of those two.
  6. JamesS4cab
    JamesS4cab Well-Known Member
    1,191
    94
    I used an adjustable wrench and set it to the width of the clamp when it was closed that would mean that the wrench was fully pinched together. I put a cable tie on the handle so when i had it fully pinched i could clamp the wrench shut using the cable tie and then just move the clip upwards and out the way. Then its just pulling the hose (oooo er missus) until it comes off. Took about 10 mins all in.
  7. RedDejavu
    RedDejavu Well-Known Member
    1,806
    337
