How to remove snow from the car... Winter is coming !
S3 Paul Oct 28, 2010
  1. S3 Paul
    S3 Paul Well-Known Member Regional Rep
    2,825
    107
    Is there a safe way to clear snow from car paint work?
    I was thinking from the weather reports i keep seeing... sooner or later im going to open the curtains and see a white S3 where i parked a blue one the night before
  2. JD09
    JD09 I'm not modding, I'm improving VCDS Map User
    3,096
    46
    Interesting one, I would warm the car up personally... I understand your concerns though... snow sliding down paintwork, with potential grit in it is not wanted!
  3. John @ PB
    John @ PB Member
    360
    A very slick surface should repel snow to a large extent - something like Werkstat Acrylic is very slick. I'd try not to touch the snow unless it's really deep.
    For the glass and headlights, a top quality glass sealant like Nanolex Premium Nanolex Premium Glass Sealant | Nanolex Car Care & Detailing Products or Urban Nanolex Urban Glass Sealant | Nanolex Car Care & Detailing Products will help stop frost bonding and also prevent snow building up.
    (We had some snow here last week. Not quite the 4ft we had last winter yet though.....)
  4. Fahim
    Fahim Member
    278
    Why not just buy a car cover if your so worried about the snow?
  5. John @ PB
    John @ PB Member
    360
    Probably because they'll cover the car in scratches.....
    If the car isn't spotless when a cover's applied, or if the cover isn't spotless on the inside, as you move the cover over the paint, it'll scratch the paint.
  6. JD09
    3,096
    46
    Regardless of cleanliness, 99% of car covers will scratch due to what they're made of as well! Had this experience after wanting to protect the car over a two week holiday (bird droppings etc). Came back to a car needing faint correction again.
    Not happy.
  7. John @ PB
    John @ PB Member
    360
    Not good at all.
    My post was based on non-experience: I've never used a cover. And never intend to! Your post has confirmed that even further.
  8. beanoir
    beanoir Large Member
    2,171
    31
    Snow must be cleared from a car before driving it anywhere as it's a danger to other road users when iced up clods of it fly of your car at 50mph into their windscreen.
    Why not justy pour warm water over the car, I mean luke warm, avoiding pouring directly onto glass and you'll be fine. Couple this with heating on in the car to ensure that windows don't re-ice. Works for me and has done for years.
  9. personally use a dustpan (with rubber lip) to shovel the wind screen clear but obviously not the paintwork, after a slow crawl down the road most loose stuff will fall off as you gather speed (if you can)
  10. Nutkin
    Nutkin Member
    830
    I used to put a towel on the windscreen, get out lift off and away you go.
  11. Nutkin
    Nutkin Member
    830
  12. Fahim
    Fahim Member
    278
    Wouldn't that just cave in under snow?
    Doesen't look sturdy enough to withstand a bit of snow, but going in the right direction i suppose.
  13. FranA3
    FranA3 FMDETAILING Regional Rep Site Sponsor Gold Supporter Audi A3 Team Brill Red
    7,235
    328
    i would say the best way is to try and keep your car clean so if the snow does slip down the paint its got less chance of scratching it , what i did last year was to warm the car up
  14. nwmlarge
    nwmlarge flat out
    219
    usually i clear the snow almost down to the surface by hand then pour warm water on all windows etc to clear the rest.
    to be honest though if there is a lot of snow i call in snowed in and go back to bed!
  15. Jonay
    Jonay Member
    274
    tbh the water doesnt need to be all that warm! just straight from the tap does it for me! :)
    I used to not really care with my Corsa/106 and just push/slide it all off.. but i've been paying special attn. to my A3 now and wouldn't dare!
  16. ccm1
    ccm1 Member
    68
    i have a small portable heater, like a mini space heater, set it to a gentle heat and it clears snow in seconds. i also have a bar heater specifically to leave under the car to warm the engine before starting it in sub zero temperatures.
  17. pi quattro
    pi quattro Member
    127
    i drive fast, it blows off, stop hard and it falls off. then i call my mate and ask him if he wants my quattro to pull his 5 series off his driveway!!! Ha Ha
