how to remove seized rounded allen bolt?
205man Mar 17, 2013
  1. 205man
    205man Active Member
    1,072
    14
    as some you know my water pump gave up, so my mate came round to help me pull car apart but we hit a snag.
    we cant get the idle pulley/bracket off, because the bottom allen key bolt is completely round inside and pretty sized, and the one above seem to be also seized but the head seems ok i just need better allen socket before i risk the head on that going.
    so an ideas on how to remove rounded allen bolt, ive seen load of ideas on the net, but thought id ask what has worked for you.
    the strange thing is the last time this was taken apart was 4 years ago when main dealer fitted new cam belt etc ???????
    cheers
  2. towcestervag
    towcestervag Member VCDS Map User
    165
    i use irwin extractors
    they cut into the outer part of the bolt and work very well
  3. cerips
    cerips Member
    54
    Irwin extractors or hammer in a Torx or XZN bit.
  4. Blue_Thunder
    Blue_Thunder Well-Known Member
    1,771
    31
    +1 for the Irwin Bolt Grips. Excellent bit of kit!
  5. Broken Byzan
    13,237
    465
    xzn and a hammer here, not failed yet.
  6. Todd1983
    Todd1983 Member
    147
    Hammer in a Torx
  7. PAULF
    PAULF Active Member VCDS Map User
    712
    66
    +1 for the Torx bit, or I have a stud remover that sometimes works, or pipe stilsons.
  8. aragorn
    18,152
    766
    Or weld on a standard bolt.
  9. Steve_D
    Steve_D Member
    112
    I used an angle grinder to make a standard socket fit on... came off a treat and replaced the bold.
    That was on the rear caliper carrier bolt
  10. ctd
    ctd Member
    106
    torx bit for me every time
