how to remove scuttle panel?
johal87 Mar 11, 2009
  1. johal87
    johal87 Member
    331
    hi just a quick question
    any idea how to remove it? ive take the wiper arms off, just left with the panel...
    i can't see any screws etc :s
    thanks dudes
  2. warren_S5
    warren_S5 Moderator Staff Member Moderator VCDS Map User
    7,210
    2,481
    I'd have to assume from that observation it must be clipped in. Are there any obvious areas that seem to allow you to squeeze a blunt edged tool in and have a look underneath?
  3. johal87
    johal87 Member
    331
    from the side of the panel nearest to the bonnet you can raise it.. not much but you can raise it enough to see inside..
    from that, i can't see any clips etc.. im thinking maybe some kind of seal or bond around the edge of the screen?
  4. JohnS3
    JohnS3 Active Member
    3,028
    You're nearly there. These are the instructions from ELSA
  5. johal87
    johal87 Member
    331
    john thats brilliant, thanks alot for that, should get chance to try it out later, hope fully i'll have working wipers again :)
  6. JohnS3
    3,028
    Did you fit HIDs and kill your wiper motor?
  7. johal87
    johal87 Member
    331
    yes mate you got it one!
    i was lucky and i got a good price on a spare motor etc... and fitted it my self, i've heard of people being struck with £300 bills!!
  8. JohnS3
    3,028
  9. steve184
    steve184 Active Member
    1,138
    be carful you don't force it though as you may find that it doesn't go back on again and sit flush against the windscreen seal again - leaving a gap at the bottom of the windscreen - i had this issue with my last A3 and apparently the only fix is a new windscreen!!!
  10. Lukeyb
    Lukeyb Active Member
    397
    53
    careful you dont snap it as they can be pretty brittle if cold too, was the warning i got when i blew my wiper motor too
