How to remove gearstick trim?
Discussion in 'A3/S3/Sportback (8P Chassis)' started by rokape, Jul 30, 2012.
  1. rokape
    rokape Member
    Jun 21, 2012
    87
    Hi,
    I want to change my aluminium trim on my A3, seems to of got corroded / veined somehow from the previous owner. I will get a new one from Audi, but I can't work out how to remove it.
    Done some searching, found these:
    1. http://www.audi-sport.net/vb/a3-s3-sportback-8p-chassis/81545-how-do-you-remove-trim-gear-stick.html
    2. Fourtitude.com - DIY: Shift Knob Switch (Pics)
    Only, I can't work out how to change just the trim? I don't want to change the gear stick.. any ideas?
    I have managed to get the trim up, but ending up like this: http://img.photobucket.com/albums/v306/jokr/Audi/SV300078.jpg
    Any thoughts?
    Thanks! :)
  2. Advert Guest Advertisement
  3. moag
    moag she's no d-turbo
    Sep 6, 2010
    821
    35
    There is a metal butterfly style clip which clamps the cover on to the gear knob and stick. Cut it off!
  4. rokape
    rokape Member
    Jun 21, 2012
    87
  5. moag
    Sep 6, 2010
    821
    35
    Yep thats the one. Im not sure if a cable tie would suffice as the metal ring clamps the blue plastic on to the gear stick. You may be able to get a part number off the ring. Alternatively you can get them in any decent motor factors/DIY store (the rings are used for clamping hoses on)
  6. rokape
    rokape Member
    Jun 21, 2012
    87
    Cool thanks man! I know what you mean now, the ones you tighten with a screw driver?
  7. moag
    Sep 6, 2010
    821
    35
    Nope, not jubilee clips. I think they would foul the cover.
    Im talking about this style clip...
    You just nip the two "sticky outty" bits with side cutters to tighten. Let me know if you have any bother sourcing one and il post one over to you!
  8. rokape
    rokape Member
    Jun 21, 2012
    87
    Ok awesome. Thanks!
    I presume it's ok to remove it before I get the clip? Ie I just shouldn't pull it up else it will fall off? Or does the clip prevent it from falling down too?
  9. TimG
    TimG Active Member
    Feb 21, 2004
    942
    45
    Prevents it from twisting in your hand too. I replaced mine with a cable tie and its fine. Just pulled it up nice and tight.
  10. OCD-A3
    OCD-A3 Member
    Jul 17, 2011
    118
    +1 for the cable tie. I've been using one without issues for a few years.
  11. rokape
    rokape Member
    Jun 21, 2012
    87
    I took it off & got it ready for a new one. I cable tied it, think they were weak ties or not tight enough.. anyway I decided to use a jubilee clip, works perfectly & really tight! :)
    Got to source a new trim / boot now.
