HOW TO REMOVE ENGINE COVER??
bigcheese Jan 27, 2011
  1. bigcheese
    bigcheese Member
    51
    hi guys,
    need some help asap, i got oil coming out from all sorts of places but i cant see exactley where its coming from because i can remove the bloody engine cover/ air box. it just feels like its gonna snap and i cant see any fixings that hold it down, anybody know how to remove it?? also has anyone had trouble with there charcoal filter? the engine managment light keeps coming on and vag com shows it being the charcoal filter. i have looked at it and can see where at some point petrol has run down it. ordered a new one from audi (80 bloody quid), the guy i spoke to says it very unusual for this to go, has anyone els had this isue or know where i can buy a charcoal filter cheaper??
    cheers
  2. mike foster
    3,967
    What car is it ?
  3. bigcheese
    bigcheese Member
    51
    sorry forgot to mention it a s3 8p
  4. mike foster
    3,967
    No - which engine, petrol, diesel ? Engine code ?
  5. brough74
    brough74 Member
    423
    22
    Basically you need to start at the left corner and give it a good tug upwards then work your way around, make sure you are on a solid bit of plastic when you do it. Underneath there is 4 lugs that get pushed into 4 rubber grommets. When i put mine back on i used copper grease to make it easier in the future. Plenty more info on removing the engine cover on this site if you search for it.
  6. mike foster
    3,967
    Yes - thats the same as mine which is a 2.00l diesel.
    Didn't know if the petrol ones were the same hence my asking the question !
  7. bigcheese
    bigcheese Member
    51
    2.0ltr petrol engine code bkd
  8. bigcheese
    bigcheese Member
    51
    brough74- am i pulling the whole lot or just the top half of the unit? im asuming it comes apart in half anyway!
  9. mike foster
    3,967
    BKD engine is 2.0 litre DIESEL. Hope you haven't put petrol in !!
    Instructions given above are correct. You need to remove the oil filler cap and dipstick first.
    You really need to give it a hefty tug to get the cover off.
  10. mike foster
    3,967
    No it doesn't come apart - it's all one piece.
  11. bigcheese
    bigcheese Member
    51
    oh right sorry mike i asked my mate what engine code it is as he is the one with the vag com and usaully know that sort of stuff. its deffently petrol. so just grap the whole unit in one corner and give it a bloody could pull yeah?.
  12. mike foster
    3,967
    Presumably you have removed all obvious connectors etc. first and anything else you can see is in the way.
    After that then yes - a hefty tug around the edges will do it.
    Once you've done it first time it will be obvious and easy from then on !
  13. brough74
    brough74 Member
    423
    22
    Its all one piece you need to remove the duct at the front for the air feed to the filter, and then in the back right corner the pipe that connects to the turbo.
  14. bigcheese
    bigcheese Member
    51
    cheers mike just got it off it totally makes sense now. just got to figure out what the part is that the oil is coming out of!
  15. mike foster
    3,967
    Good man - hope you get sorted !
