How to remove climate control unit switches/facia?
c_w Sep 17, 2010
  1. c_w
    c_w Well-Known Member
    1,163
    87
    Hi, can someone help on how to remove the climate control unit? I've removed the radio but can't see any obvious clips or screws for it. I want to get to the back of the unit, thanks.
  2. sijones
    sijones Member
    160
    it just pulls out, but if it's at the bottom, then if am remembering correctly you have to take the side handles off, an there 2 screws under gearbox cover as well to get the handles off... then just pulls out.
  3. c_w
    1,163
    87
    Thanks, my car has the standard single DIN radio so the climate is in the "middle", so it lerally just pulls out!? Where's best to pull as I did try it a little but didn't want to break anything (this was with the radio out).
  4. PH1L
    PH1L Gievf Buckets
    3,851
    40
    pul solidly from the bottom and the top it will come out same procedure for both double and single din
  5. NHN
    29,510
    1,764
    Problem with just yanking them out is the clips can ping of & get lost in the center console, I strongly advise not doing this as its a strong possibility whole console out if this happens as could have a constant rattle from the clip whilst driving.
    The spring clips need to be depressed slightly to remove climate easily, once 1-2 are loose the other 2 dont need touching as they are made loose by the lack of pressure on the other 2/unit fixing, get torch in there & have a poke about.
  6. PH1L
    PH1L Gievf Buckets
    3,851
    40
    never had that happen but then i usually yank the bottom and ease the top out with plastic spreaders
  7. NHN
    29,510
    1,764
    I have & believe me its a big ball breaker when it does, I mean massive, found 1 hidden under the airbag controller, but of course cant get to this without the whole center console coming out.
  8. PH1L
    PH1L Gievf Buckets
    3,851
    40
    center console still isnt that bad a strip though but i must admit id be pissed if it happened to me ;)
  9. NHN
    29,510
    1,764
    Depends whose doing it huh Phil lmfao
  10. Khufu
    Khufu Well-Known Member
    5,704
    31
    I guess I too have been lucky!
  11. FranA3
    FranA3 FMDETAILING Regional Rep Site Sponsor Gold Supporter Audi A3 Team Brill Red
    7,245
    340
    i had one go ping when i fitted my hands free kit in my car now its rattling its tits off behind the radio somewhere i'll pull it apart sometime its doing me head in so i can strongly recommend doing as nhn says
  12. NHN
    29,510
    1,764
    I rest my case lmfao, thats a bitch to find aswell, double sided sticky tape helps on end of a coat hanger.
  13. FranA3
    7,245
    340
    oh yeah it seams that way lol, i'll give it a crack tommorow sometime
  14. PH1L
    PH1L Gievf Buckets
    3,851
    40
    haha guess ive been lucky guys as ive taken units in and out 20+ times now with no problem
  15. NHN
    29,510
    1,764
    Thats cause all your spring clips are now in the footwell lmfao
  16. PH1L
    PH1L Gievf Buckets
    3,851
    40
    haha its been on other cars, and they were always still in place its my magic hands ;) though the missus probably has some witty retort to that
  17. c_w
    1,163
    87
    Well it came out with a bit of a harder but controll pull! Thanks. It felt to me that the top unclipped and then it kind of came out and unhooked from the bottom.
  18. NHN
    29,510
    1,764
    Does this read as though we're on a car site or what lmfao
  19. PH1L
    PH1L Gievf Buckets
    3,851
    40
    ;) haha nige weve gotta liven up a sunday somehow
  20. c_w
    1,163
    87
    Did it again today and it was much easier coming out this time hehe
  21. NHN
    29,510
    1,764
    I hear swarfega would make it easier with a slight bit of roughness lmfao
  22. PH1L
    PH1L Gievf Buckets
    3,851
    40
    aww thats just wrong mate, on the other hand i hear barrier cream can help deal with friction burns ;)
  23. NHN
    29,510
    1,764
    lmfao, bit like philadelphia, wrong but so right lol
  24. iwBen
    iwBen Be Gentle VCDS Map User
    114
    :uhm:
  25. PH1L
    PH1L Gievf Buckets
    3,851
    40
    this thread went downhill very quickly, without the usual crew too
  26. NHN
    29,510
    1,764
    whats that say about us then Phil lmfao
  27. PH1L
    PH1L Gievf Buckets
    3,851
    40
    oh shi lol too truemate too true. need a holiday!
