How to remove badges (Superglue)????
blanc May 23, 2011
  1. blanc
    blanc Member
    47
    Hi All,
    The last owner put rs4 badges on my quattro avant. What an idiot....he used superglue to add inslut to injury. I damaged the laquer taking it off the side skirt with a heater and a blade. I really want to remove the badge from the rear of the car. Any Idea how to do this without damaging the paint? Also can it be buffed out with a machine polisher if it does leave behind a mess?
  2. Dilligaf-UK
    Dilligaf-UK Chugging along VCDS Map User
    197
    Generally if you warm it up using a hairdryer and use the edge of a credit card as a scraper, you should be able to remove it without damaging the paint.
    Let me know how you get on - I've got an S4 badge to remove!
  3. xs2man
    xs2man Member
    791
    Thats how you would do it with the factory glue anyway. Superglue could be a different story though. Maybe try calling up the superglue people? Or google it?
  4. quattrojames
    14,050
    574
    Agreed, you'd need a solvent to weaken the glue, but I'd seek specialist advice so you don't damage the paint first. I'm sure the bond between the badge and the paint will be stronger than between the paint and the bodywork!
  5. mikeh126
    mikeh126 Member
    152
    I think acetone, nail polish remover, or a 'debonder' should do the trick.
    BUT, as quattrojames says, I'd get specialist advice first - maybe by ringing a superglue manufacturer - say, 'LOCTITE'?
    Their distribution agent is a firm called HENKEL Ltd., and their Technical Service Dept tele no is 01606 593933.
    Worth a try?
  6. Mrmok
    Mrmok Member
    60
    Don't try the heat method it wont work and will cause more damage, it's a totally different adhesive to factory fitted sticky backed badges. Hospitals use water to unstick idiots who have superglue mishaps as it breaks down with water.......not sure how you could put this into use in this situation though........I reckon you might be 'stuck' with them
  7. Gaz!
    Gaz! Member
    159
    14
    Soak some metholated spirit on to a small sponge, soak the badge well for afew mins. Pick gently at the badge whilst still soaking, it will come away slowly. Dont force it or you will take the laquer off. After the badge and any leftovers is off wash with lots of water or it may stain the laquer.
  8. Turkster
    Turkster Bro.Paul 2.5TDI Quattro Sport
    2,797
    47
    im sure there is an anti super glue agent,
  9. paul20v
    paul20v Audi fanatic
    1,113
    Super glue actually eats into lacquer so you are going to leave marks if removing the badges if it is super glue thats been used .
  10. blanc
    blanc Member
    47
    Howdo you repair lacquer?
  11. C17LJR
    C17LJR Member VCDS Map User
    513
    rub it down & re-lacquer it, providing its not got through to the base colour as well
  12. Grangey.
    Grangey. Member
    226
    id take it to a bodyshop and get them to look/sort it, and least itl be properly finished...although the cost could be another matter
